keyless entry stopped working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-15-2007, 12:48 PM
99fatboy 99fatboy is offline
99fatboy is starting off with a positive reputation.
Hello all, on my 99 DRW my keyless entry just stopped working. Either remote doesn't respond. I replaced battery on one of the units just to eliminate the obvious. I checked a few fuses and they are ok. I am planning a more thorough search one evening but any ideas what I should be looking for? Don't know if this is related or not but my left turn signal blinks very fast all of the sudden as well.
-Rick
Old 05-15-2007, 04:35 PM
ccerniglia's Avatar
ccerniglia ccerniglia is offline
ccerniglia is gaining momentum as a positive member of FTE.ccerniglia is gaining momentum as a positive member of FTE.
Rick,
Take your key put it in the ignition and turn it to off, then turn it from run to off 8 times ending with the key on, the locks should cycle once. if they do not, then you module is dead. If they do cycle, press one button on a single remote and they should cycle once more and then turn the key back and pull it out.hopfully if should work by then.
Old 05-16-2007, 02:33 PM
can't explain it but I got under the dash and unplugged the unit and pulled each fuse and plugged everything back in and it started working again. Weird. Thanks for the info anyhow ccerniglia. I'll keep it handy for the future.
Backwards from the normal question, can you unprogram a keyless entry remote twigsV10 Expedition & Navigator 13 09-28-2015 11:33 AM
keyless entry module swap? bubba_3711 1994.5 - 1997 7.3L Power Stroke Diesel 17 04-26-2015 09:55 PM
99 F250 Keyless Remote Entry ? Haveyoudrivn1lately? 1999 to 2016 Super Duty 25 10-26-2014 06:18 PM
Door Keyless Entry Help!!! fx4king2011 2009 - 2014 F150 1 08-30-2014 10:21 AM
Factory Keyless Entry Wires? AndeyHall 1999 to 2016 Super Duty 8 07-29-2013 05:57 PM
Tags
2001, 99, duty, entry, escape, f150, f250, ford, keyless, light, quit, stoped, stopped, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
