5.4L Coil Pack - Ford Truck Enthusiasts Forums
5.4L Coil Pack
Old 09-29-2002, 04:35 PM
gunther32 gunther32 is offline
gunther32 is starting off with a positive reputation.
5.4L Coil Pack
Just before my warrentee ran out I had a bad miss in one of the cylinders, followeed shortly thereafter by the "Check Engine" light. Dealership replaces coil pack and plug under warrentee.
Funny thing happened around 2x the warentee milage. I just started getting this miss in one of the cylinders.
Is there any way to easily test for the failed coil pack. Does anyone know the Ford Service # for it. Better still, is this even worth replaceing myself.
Old 09-29-2002, 08:59 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
5.4L Coil Pack
The coil packs are easy to replace - except for the back cylinders where it is a bear to get to them. A code reader would help you out a bunch since you could find the pack that was bad.
Old 10-04-2002, 01:51 PM
anthonyk anthonyk is offline
anthonyk is starting off with a positive reputation.
5.4L Coil Pack
I have the same problem with my 97f150 2wd, 4.2Liter.....I would like any more information anyone can provide on fixing it myself...
Old 10-06-2002, 07:12 PM
5.4L Coil Pack
One little bolt holds that coil pack in place. Once you know which plug/pack it is, they are very easy to replace. If you have a doubt try the front one on the right side (5.4L). You will need a air compressor. You must blow out the hole where the plug sits to make sure no dirt or rocks fall into the engine.
Old 10-06-2002, 08:15 PM
blueovalinvestments's Avatar
blueovalinvestments blueovalinvestments is offline
blueovalinvestments is starting off with a positive reputation.
5.4L Coil Pack
Had this happen on my van. Code indicated #7 wasn't firing. Thought it might be a bad connection so I cleaned and re-connected the coil. Ran fine for a week, then came back. This time I swapped #7 and #5 to see if the problem moved to #5. That was almost a year ago and the miss never returned.
Old 10-07-2002, 12:11 AM
rkjerue rkjerue is offline
rkjerue is starting off with a positive reputation.
5.4L Coil Pack
Old 10-18-2010, 07:10 PM
bucs47chris bucs47chris is offline
bucs47chris is starting off with a positive reputation.
I have a 2001 ford expeidition. what is the best coil pick to use?
Old 10-19-2010, 05:23 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
Old 10-19-2010, 08:40 PM
ok thanks so if one is bad should i do just that one or all off them
Old 10-20-2010, 06:32 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
The link above is a great deal and I run them on my truck.
It was recommended to me to get the set for the V10 so you have 2 extras when you buy them.
I'm glad I did because 1 was bad out of the 8 I put on. Instead of messing with sending one back I just put one of the extras on and now I still have one extra good one for another time.
Old 05-30-2011, 08:39 AM
northern2wdexpy northern2wdexpy is offline
northern2wdexpy is starting off with a positive reputation.
Has anyone bothered to try the MSD or Accel coil packs for the 5.4? just wondering if they are any better?
Old 05-30-2011, 08:59 AM
phil6608's Avatar
Quote:
Any better then what?
There no better then the stock Motorcraft!
Same as the cheep ebay ones basically. Just with more hype/BS...lol
Old 05-30-2011, 09:21 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
I agree, the Accels are painfully bad, the MSDs are ok, but remember, they can't be better if they are cheaper. In coils, you get what you pay for. I would pass on the eBay ones, and replace the one(s) that have failed with OE Motorcraft coils.
Old 06-01-2011, 01:18 PM
bbsitum bbsitum is offline
bbsitum is starting off with a positive reputation.
You should try first what I did. But for COIL PACK not COIL OVER PLUG.
Old 06-01-2011, 01:36 PM
ahall8 ahall8 is offline
ahall8 is starting off with a positive reputation.
When you check your codes at the local big box parts store (or on your own scanner) the last number of the misfire code will be the cylinder. The back two are a PITA as mentioned, but the others are remove the one 8-10mm bolt (can't recall) unplug the electrical hook up, pull it off and put a new one on.
2004 Coil Packs meade01 2004 - 2008 F150 2 02-06-2015 11:56 AM
94 ranger 4.0 melts coil packs in seconds kunard333 Ranger & B-Series 18 08-24-2014 11:17 PM
'05 3rd Cyl. Misfire code, bucking and a ? vanvoorenfamily 1997-2006 Expedition & Navigator 25 11-13-2011 11:39 AM
coil pack firing order mniewald 1999 to 2016 Super Duty 2 07-26-2011 04:46 PM
5.4 Coil Problem FKNVA Modular V8 (4.6L, 5.4L) 17 12-22-2010 05:05 AM
Tags
2003, 54, 54l, coil, coils, f150, fi, ford, liter, pack, prices, problems, replace, test, testing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
