Dometic refrigerator RECALL FIRE POTENTIAL
FROM RVNET.com Tech Issues
Dometic 2 door refrigerators
From the NHTSA website:
Dometic Recall NHTSA Campaign ID 06E076000
Make / Models : Model/Build Years:
DOMETIC / NDR1062 9999
DOMETIC / RM2652 9999
DOMETIC / RM2662 9999
DOMETIC / RM2663 9999
DOMETIC / RM2852 9999
DOMETIC / RM2862 9999
DOMETIC / RM3662 9999
DOMETIC / RM3663 9999
DOMETIC / RM3862 9999
DOMETIC / RM3863 9999
Manufacturer : DOMETIC CORPORATION
NHTSA CAMPAIGN ID Number : 06E076000 Mfg's Report Date : AUG 28, 2006
Component: EQUIPMENT: RECREATIONAL VEHICLE
Potential Number Of Units Affected : 926877
Summary:
CERTAIN DOMETIC TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN APRIL 1997 AND MAY 2003: SERIAL NOS.
713XXXXX THROUGH 752XXXXX;
801XXXXX THROUGH 852XXXXX;
901XXXXX THROUGH 952XXXXX;
001XXXXX THROUGH 052XXXXX;
101XXXXX THROUGH 152XXXXX;
201XXXXX THROUGH 252XXXXX;
301XXXXX THROUGH 319XXXXX,
INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS AFTERMARKET EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence:
THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Remedy:
THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN BETWEEN APRIL AND JUNE 2007. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
The following is extracted from the notice provided by Dometic to the NHTSA dated 8/26/06:
The potential defect is associated with cooling unit at the back of the refrigeration cabinet.
A fractional percentage of the potentially affected refrigerators have experienced a fatigue crack that may develop in the boiler tube in the area of the weld between the boiler tube and the heater pocket. A fatigue crack may release a sufficient amount of pressurized coolant solution into an area where an ignition source (gas flame) is present. Dometic's investigation has shown that a simulated release of cooling solution (refrigerant) in the area of the boiler, under certain conditions, could be ignited by the presence of an open flame. A boiler fatigue crack with the loss of cooling solution without ignition would result in a non-operational refrigerator that is not a safety issue. Under certain conditions, the released coolant could ignite and result in a fire. In order to have a fire, at a minimum, all of the following conditions must exist:
In April of 1997 Dometic modified the design of the affected refrigerators by increasing the wattage of the heating element from 325 watts to 354 watts. All production of the affected units from April 1997 through May of 2003 utilized the 354 watt heating element. In May of 2003, in order to improve the operating life of the refrigerators, Dometic returned to the use of the 325 watt heating element which it continues to use today. It is now believed that the use of the higher wattage heater contributed to abnormal fatigue in the boiler tube.
The products in question are all refrigerators used in the original manufacture of recreation vehicles or as replacement equipment for recreation vehicles. The total population of refrigerators potentially containing the defect is 926,877. Dometic estimates a potential maximum incident rate of 0.01% related to boiler fatigue cracks that leak and may result in a fire. There have been no incidents of injury or death related to the affected population of Dometic refrigerators.
Dometic became aware of the occurrence of fires which may have involved their products and retained an independent engineering testing laboratory to fully evaluate and investigate any potential defect in their refrigerators which might result in a fire. A number of returned units were analyzed and microscopic fatigue cracks which could release coolant into the area of the burner were identified in the boiler tube metal in the area of the weld between the heater pocket and boiler tube. Tests simulating the cracks were conducted the week of August 18, 2006 and confirmed a possible cause of fire in the refrigerators under certain conditions. These test results prompted the preparation of this notice.
Dometic continues to gather information on the potential defect and will forward additional relevant information as it becomes available.
Dometic has not yet identified a proposed remedy for the potential defect. Dometic will continue a testing program designed to identify and evaluate possible remedies. This evaluation will take place both in the United States and in Sweden. Once a remedy has been identified, Dometic will initiate or participate in a remedy campaign initiated by the original equipment manufacturers and aftermarket suppliers who have purchased, sold, and distributed these products. A list of original equipment manufacturers and aftermarket suppliers to whom Dometic has sold the potentially defective refrigerators is being prepared and will be provided to the NHTSA upon its
completion.
The following is extracted from the NHTSA response on 9/18/06:
Please provide the following additional information and be reminded of the following requirements:
Summary:
Consequence:
Remedy:
Notes:
completion.
I have more in-depth info on that.
The nature of the recall package is a lot of sheet metal to surround the burner assembly, but also there is a circuit change.
On the side of the refrigerator chimney a button thermostat is attached with rivets that will open up if temperatures detected by it are too high.
There is also a secondary device that senses temperatures at the base of the chimney near the burner assembly that will disconnect if high temperatures are detected there either.
The primary defence is to surround and contain any high heat source in the area of the burner with a complete heat shield, the secondary measure is a redundant ("FAIL SAFE" If one device does not shut it down, the other will) power-shutoff to the gas solenoid and entire operating system.
I've installed about ten of them so far.
Harlan Hobbs
01-11-2022 10:59 AM
BPofMD
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-15-2014 08:47 AM
Furyus1
General Automotive Discussion
04-08-2014 06:45 AM
porthole
6.7L Power Stroke Diesel
12-16-2013 02:18 PM
RV_Tech
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
17
08-19-2013 12:46 AM
