351 windsor piston to deck clearance - Ford Truck Enthusiasts Forums
Old 05-14-2007, 07:12 PM
funfor funfor is offline
funfor is starting off with a positive reputation.
hi. i have a 1986 351 h.o and i am putting on a set of c90e 69 heads. i need to know how much clearance there is when piston is at top dead centre to the deck. i f anyone knows this or has any hints for me it would be greatly appreciated. i am just getting ready to bring the heads to the machine shop to get done. thanks.
Old 05-15-2007, 10:04 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
why not ask the machine shop
Old 05-16-2007, 02:15 AM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Hi Funfor,
Well there's quite a few things that determine the deck clearance. Some cheaper rebuilder pistons have reduced compression height, there is manufacturing tolerance in original parts, etc. Since you will be replacing the heads, you will be able to measure the clearance directly when they are off. I would note each cylinder clearance, then you would see if one bank were higher than the other.
Deck Clearance dayde Modular V10 (6.8l) 1 01-07-2017 08:02 PM
Piston to Deck Clearance .0315 RatRodAlex 1999 - 2003 7.3L Power Stroke Diesel 5 08-21-2015 09:04 PM
Looked everywhere!!? What is stock late 351w piston to deck clearance? monkei Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 04-17-2010 10:38 AM
351W stock spec and stroker questions monkei Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 01-20-2009 09:01 PM
Deck Clearance Clarification Ryan356 Performance & General Engine Building 8 07-11-2004 05:57 PM
Tags
351, 351w, 390, block, clearance, concerned, deck, engine, ford, piston, rebuilders, small, tolerance, whats, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
