Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2007, 03:48 PM
f460 is starting off with a positive reputation.
New 6.2 to use CGI Block
Well I guess if you are a FORDifile you already know this. Cleveland casting is slated to be mothballed. TUPY the company that casts the blocks for a number of diesel engines and all NASCAR engine blocks including Toyota will cast the CGI block for the Boss V8. The company decided against spending the money for a full CGI line in Cleveland. This decision was made a few months back as a way to lighten up the block for the 6.2 V8 and get better strength. A Nascar GM block cast in CGI weighs about 85lbs less with equal or better strength compared to normal grades of cast iron used in GM's previous engine blocks.
So this looks like it unless the volume of 4.4 diesel blocks gets up high enough too make casting them in Cleveland profitable.There are rumors of offers for the casting plant as 2 new topline melting furnaces have already been installed.
Tupy is the largest foundry group in the world as of today. The Cleveland engine plants will keep going with a new version 3.0 duratec and a new 3.5 and a 3.7 variation to come on line probably within the next year when the Flex and the new Explorer hit the streets. It is hard to compete with Tupy, but maybe the 4.4l diesel will be a big seller and some of that volume will make it profitable to cast it at the Cleveland Casting plant.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2007, 08:17 PM
i3shooter is starting off with a positive reputation.
Thanks for that info. Do you know where the 6.2 is going to be assembled. I am wondering for what model year and if it is just going to be a f150 motor or if it is going to go into the superduty line up as well.
  #3 (permalink)
Old 05-15-2007, 04:11 PM
I thought it would be Windsor or Essex engine but does not look like it now. With the change to CGI for the engine blocks that took Cleveland out of the picture for casting the cylinder blocks. Romeo was to build the engines for Mustangs and for the new rear drive large car to replace the Crown Vic. Maybe Romeo will build all of the engines now. Some tooling is at Windsor for making cylinder heads as that is to be handled by NEMAK a company which holds about an 85% share in Windsor casting. But I doubt that NEMAK would have room for full production at Windsor as that plant casts an aluminum V6 block for GM.
Everybody is pretty quiet about the Boss or what ever they decide to call it.
The most I have heard is it is built for off-road and marine use in mind. The bore spacing will allow for a new 429 if that is what it takes to be competitive.
  #4 (permalink)
Old 05-15-2007, 09:36 PM
04 FX4 Lineman is starting off with a positive reputation.
I would alsmost bet that we will not see the 6.2 in the 09 with fuel prices being what they are I am guessing all we will see is the diesel for now until fuel comes down if ever???
  #5 (permalink)
Old 05-16-2007, 12:25 AM
Matts72's Avatar
Moderator- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Diesel has dropped about $.30 a gallon here... I think I saw $2.87/gallon, about $.22 cheaper per gallon than 85.5 octane here.
  #6 (permalink)
Old 05-16-2007, 07:36 AM
scottie2hottie's Avatar
scottie2hottie is starting off with a positive reputation.
yesterday diesel here was 2.66 where 87 octane was 3.19. Thank god for Powerstroke :P
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
1994 F350 "Possum"
1982 F250 "Amos Moses"
1975 F250 "Mean Green"
Quote:
Originally Posted by CMNZ59
Horsepower is how fast you hit the wall, torque is how far you push the wall once you hit it
Proud to be an OHIO BOY
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
