do i have the wrong fuel filter removal tool? (pic) - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 05-13-2007, 06:28 PM
5.0Torx's Avatar
5.0Torx 5.0Torx is offline
5.0Torx is gaining momentum as a positive member of FTE.
hey all, been trying to change the fuel filter on my moms 2000 Exped (4.6 4wd) for the past hour, to no avail. i got the little metal clips off pretty easily but trying to get the fuel lines off the filter was a total pain. I think i might have the wrong fuel filter removal tool. what do yours look like?
Old 05-13-2007, 08:46 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
looks like it
It's a pain even with the right tool.
Old 05-14-2007, 01:37 AM
5.0Torx's Avatar
granted, but that doesnt really tell me if it is the right tool...
Old 05-14-2007, 02:29 AM
Luzer27 Luzer27 is offline
Luzer27 is starting off with a positive reputation.
Yes and No
Yes you have the right tool but it is better suited for AC connections. I have had much better success with these esp. in tight areas:
http://www.amazon.com/Lisle-37000-Co...9123831&sr=8-1
I have seen them at PepMart (Pep Boys) and also Checkers etc... Ther are around 10.00, you will have much better success. Also twist the lines or filter to free up the o-ring's which tend to dry and seize somewhat. Let us know what happens for feedback.
Dave
Old 05-14-2007, 11:20 AM
racerock racerock is offline
racerock is starting off with a positive reputation.
Quote:
http://www.amazon.com/Lisle-37000-Conditioning-Fuel-Disconnect/dp/B0002SRCK6/ref=sr_1_1/002-7397624-1276853?ie=UTF8&s=automotive&qid=1179123831&sr=8-1
Dave
I'll second the suggestion on the tools. They work great for me.
Old 05-15-2007, 05:33 PM
5.0Torx's Avatar
now im just really confused. am i supposed to twist the tool in circles, or pull on it?
Old 05-16-2007, 04:32 AM
The white ones
If you are using the ones I mentioned, get the right size one and shove it in there it will almost go flush and then pull and wiggle. Inside there is a spring that has to be expanded to be able to pass over a ridge on the inner line.
Dave
Old 05-16-2007, 08:24 AM
waterman308 waterman308 is offline
waterman308 is starting off with a positive reputation.
I have one like that on my 98 E350 van. Once you push the plastic tool into the connector of the fuel line connector, pull the connector back off the fuel line - don't try to use the tool to "push" the fuel line as you will be pushing against a ridge on the fuel filter inlet tube and go absolutely no where. You sort of "push" holding the tool against the inside ridge with one hand, and with the other, pull back on the fuel line. The tool holds open a bunch of little spring fingers that clamp over the ridge on the fuel filter inlet tube. Once held open, just pull the fuel line off. You may have to pull hard (it won't just fall off in your hand), but it will come off.
Just don't try to "push" it off with the tool - remember you'll be pushing against the ridge on the fuel fiter itself.
Be patient, it'll work.
Old 05-16-2007, 11:15 AM
buzzard's Avatar
buzzard buzzard is offline
buzzard is starting off with a positive reputation.
Quote:
Yours will work just fine so long as it's the right size (5/16), just be patient.
Old 06-21-2007, 11:29 AM
2001F250Crew2wdPSD 2001F250Crew2wdPSD is offline
2001F250Crew2wdPSD is starting off with a positive reputation.
Old 06-21-2007, 01:51 PM
Quote:
Originally Posted by 2001F250Crew2wdPSD
Old 06-21-2007, 02:52 PM
2000Expy's Avatar
2000Expy 2000Expy is offline
2000Expy is gaining momentum as a positive member of FTE.
I use the metal type. Nevertheless, it is a PITA. I don't like getting fuel on my hands either.
Old 06-21-2007, 03:48 PM
sysman_rick sysman_rick is offline
sysman_rick is starting off with a positive reputation.
Post
Better fuel on the hands,than in the face,or running down your arms and dripping in your ears.
Old 06-21-2007, 05:15 PM
jd111404 jd111404 is offline
jd111404 is starting off with a positive reputation.
Yea been there done that.
Old 06-22-2007, 12:02 PM
2000Expy's Avatar
Who says fuel hasn't gone to all those places?
1996 F250 Fuel Filter Woes Asim Khan 1987 - 1996 F150 & Larger F-Series Trucks 9 02-19-2016 09:04 AM
Fuel Filter Replacement dharrack 1987 - 1996 F150 & Larger F-Series Trucks 8 05-05-2010 01:02 AM
Fuel filter :1 Me:0 Frustrated! brazoriastang 2004 - 2008 F150 8 08-03-2009 07:18 AM
Fuel lines wont budge loose from fuel filter(spring lock) 351coupe 1987 - 1996 F150 & Larger F-Series Trucks 16 10-22-2005 01:43 PM
Last resort: fuel line filter coupler spring k4uwc 1978 - 1996 Big Bronco 5 03-15-2004 06:24 AM
Tags
2004, 2006, 98, ac, clip, e350, filter, ford, fuel, gas, gm, line, navigator, removal, remover, tool, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
