Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aftermarket Products SPONSORED BY:
  #1 (permalink)
Old 05-13-2007, 11:10 AM
jantman jantman is offline
Garage is empty, add now
jantman is starting off with a positive reputation.
06 F-250 (5.4L) - Improve Gas Mileage?
I just bought a used 2006 F-250 XLT FX4 CC with the 5.4L V8 - my first pickup and my first Ford. I've only filled it up once since I picked it up from the dealer, so I don't have an idea of what my gas mileage really is yet. But I know from watching the needle move that it's not good.
I know there are a slew of aftermarket products that claim to improve gas mileage - air intakes, chips, putting a tounneau on the bed, etc.
I was wondering if anyone has recommendations for products that actually might make a difference (the tounneau is planned) and won't void the factory warranty?
Thanks for the input.
  #2 (permalink)
Old 05-13-2007, 11:46 AM
F250FarmBoy's Avatar
F250FarmBoy F250FarmBoy is offline
F250FarmBoy is starting off with a positive reputation.
I know of something that'll help you get the maximum mpgs you can get, but you cant buy it......................you have to do it yourself.
Stay off the skinny pedal, I know its hard not to, but trust me, the more you drive like nascar, the more you'll pay at the pump.
__________________
1985 F-350 6.9L 2x4
Flatbed, DRW, 4.10's, ZF-5 swap, buckets, push button GP's, 103k miles
1989 F-350 7.3L 4x4
Kingpin D.60, Srw, 4.10 l/s, push button GP's, ex-tree service truck, dumped utility bed for the bed off an '89 . Soon to get paint with the idea of yellow and black "boss 302" graphics....but it won't say "boss 302"
  #3 (permalink)
Old 05-13-2007, 12:22 PM
I've been doing my absolute best... which is definitely easier given that it's a new truck which I'm still not completely used to, and it's so shiny... i can't help but be wonderfully careful.
That being said, watching the needle move over the past two days... I was wondering if there's anything else that can help...
EDIT: Also, BTW, I should probably say that at the moment (and for the rest of the summer) 99% of my driving is suburban, stop-and-go. Very little highway. So whatever the actual MPG turns out to be, it will probably hurt...
  #4 (permalink)
Old 05-13-2007, 07:12 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
Make sure you have the tires inflated to the psi on the door post or a little more. Make sure you have the truck aligned properly, try to avoid sudden stops and starts, I know that will be hard in the city, but still... After that is all said and done, your engine is a giant air pump. If you can get more air in and out then it will be more efficient. So go with a volant cold air intake, and at least a cat back exhaust.
__________________
2006 Escape XLT V6 4WD
  #5 (permalink)
Old 05-13-2007, 07:27 PM
Thanks. I'm probably not going to do the exhaust due to the warranty issue, but I'll look into air intakes.
I try to be pretty good with city driving, nice slow acceleration and stops, but being a volunteer EMT, when I have to respond to a call, it's not always so laid back and fuel-economy-friendly.
  #6 (permalink)
Old 05-14-2007, 02:20 PM
wrobo23's Avatar
wrobo23 wrobo23 is offline
wrobo23 is gaining momentum as a positive member of FTE.
a tuner may help pick up a little more power and fuel economy... realize that with all mods, it gets harder and harder to stay outta the gas though. these things are indeed hogs... big, wonderful, sexxxy hogs
__________________
Wisconsin FTE Chapter - Club SNL Member #8
'99 F-250 LD XLT, SC, 4x4 with 5.4L and 3.73
Leave the bowties for the little boys... Ford Trucks all the way!!!
Quote:
Originally Posted by FarmForward
You gotta wonder if this guy's parents saw each other across the table at a young age...
  #7 (permalink)
Old 05-26-2007, 01:42 PM
OkLaHoMaF150 OkLaHoMaF150 is offline
OkLaHoMaF150 is starting off with a positive reputation.
Good thread. I have several techniques I use.
I must say though, that you have a 5.4 in a F250 which are notorious for reving higher and harder then an F150.
Anyway, with all the power adders I've bolted on I didnt see any real significant change in MPG, mainly just a notice in throttle response and interstate MPG. I've added the K&N FIPK, Helix Spacer, Flowmaster Exhaust, and just installed the Edge Evo.
With gas the way it is, I never carry RPM's over 2000. I start slow at red lights and always remember to keep the RPM's low. By doing this I can squeeze out 15mpg in town driving. On the interstate I regularly see 17-18MPG out of a 2001 Ford Screw 4x4 with a 5.4l.
  #8 (permalink)
Old 05-28-2007, 07:21 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
Fuel mileage is a function of your right foot. However, my mods have yeilded some major improvements, one time I got 19mpg on the interstate. On my trip home, I thought my gas gauge broke.
However, alot of money has gone into it, and all I expected from the mods was better performance. You have a 3v motor, so I don't know how my mods will work for you, but my best increases came after my latest tuner upgrade, factory tech valve body, gears and Royal purple fluids.
Click the image to open in full size.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #9 (permalink)
Old 05-29-2007, 03:41 PM
carbonmetallic carbonmetallic is offline
carbonmetallic is starting off with a positive reputation.
checkout the outlaw power intake, I have heard good things about them. I just ordered one for my 07 expedition
  #10 (permalink)
Old 05-29-2007, 05:48 PM
CaptGuz's Avatar
CaptGuz CaptGuz is offline
CaptGuz is starting off with a positive reputation.
if you want to improve mileage its gonna due with your gear ratios. if you want to increase efficiency, so long as its a cleanliness issue inside your engine you can use an injector cleaner or something like that. but as far as intakes and all that i doubt you'll see anything noticable.
Tags
07, 2004, 2006, 54, 54l, f250, fill, ford, gas, hard, improve, increasing, mileage, response, slow, throttle, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
