Fuel gauge problem - Ford Truck Enthusiasts Forums
Fuel gauge problem
Old 09-26-2000, 03:31 PM
AlM's Avatar
AlM AlM is offline
AlM is starting off with a positive reputation.
Fuel gauge problem
Old 12-20-2000, 07:12 PM
93bronco 93bronco is offline
93bronco is starting off with a positive reputation.
Fuel gauge problem
Recently returned from a deer hunting trip through some rough terain in the mountians of PA. Stoped for fuel and noticed the gauge was still on empty after filling up. The gauge will move between empty and 1/8 tank when braking and accerlating.
93 Bronco XLT, 5.0 118,000 MLS
Need help, Running on Empty.
Old 12-21-2000, 09:19 AM
odinmurphy odinmurphy is offline
odinmurphy is starting off with a positive reputation.
Fuel gauge problem
You probably have a bad sending unit in your fuel tank. I am not sure of the procedure to change your sending unit, in the older model broncos you have to drop the gas tank and the sending unit fits in on the top, not a very hard fix, just time consuming.
Good Luck
Murph
Old 12-21-2000, 12:58 PM
Fuel gauge problem
Is there any way to verify that the problem is in the tank befor the painful process of removal. ?
Thanks again for the response.
Old 12-21-2000, 04:08 PM
AlM's Avatar
AlM AlM is offline
Fuel gauge problem
yo!
here is a test from the archives..i searched here for "gauge"//
"i own a 95 bronco Iam also a mechanic at a ford dealer.This is a common problem with most fords which is most allways the sending unit to check the gas guage. There is a yellow wire with a whtie tracer coming off the fuel pump to the guage The easiest way to ck the guage and wiring is to disconnect the y/w wire and grond the wire on the dash side of the wire. If you can slide your hand up on top of the tank and disconnect the pump and ground out the y/w wire turn the key on and watch the gauge if the guage goes up the sender in the tank is bad, if youre going to replace the sender you may as well put a pump in it. As for the cruise if the fuses are good it could be the switches , clockspring or servo it would be hard to explain all the tests you go throught. I would say 80% of the time it would be the servo. good luck" end of quote
good luck!
Old 12-21-2000, 04:55 PM
Fuel gauge problem
YO
AIM, you the man!! Thanks for the tip & the search tip.
Old 12-21-2000, 09:26 PM
hotrodford_88 hotrodford_88 is offline
hotrodford_88 is starting off with a positive reputation.
Fuel gauge problem
Might I recommend something? If you are going to replace the sending unit. My advice, get one direct from ford. That way you'll know it's the correct part. I bought one from a parts house ($125) and found out that it read backwards. Turned out, after I dropped the tank the second time, it was for an escort!
Then I just dropped the old sender back in, only one poblem, it wouldn't work at all. So, I had to take the sender out again. The third time I pulled the sender, I took the bed off the truck (88 F-150), but I bought the corredt sending unit from Ford, and haven't had a problem since.
My sending unit cost me $175 but at least it's the correct one. And it already had the low pressure pump attached to it.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
[link:www.geocities.com/westlake_vfd/Westlake.html|Westlake VFD Website]
Old 12-21-2000, 09:28 PM
AlM's Avatar
AlM AlM is offline
Fuel gauge problem
i know nothing!..lol
nytime, i have time to reply now and look things up
btw, my 96 has pract no room above the tank..most late models with the skid plate are tight..the shid plate helps hold the tank in place, btw.
good luck dude!
Old 09-05-2010, 08:15 PM
patrick357 patrick357 is offline
patrick357 is starting off with a positive reputation.
I am going through the very same Problems with my 1993 F 250 4X4 . It is really Beginning to drive me out of my mind . when the ignition is on it reads Empty when its off its reads Half a Tank . I just Don't Know if i should replace the Sending Unit or get the Gauge Re-Calibrated as My Mechanic told me to do . He said it is the Gauge . But I Don't think its a problem with the Fuel Gauge .
Old 09-05-2010, 10:29 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
As this very old thread mentioned, it is rarely the gauge that fails and most frequently the sending unit that does. I would suggest posting this in the "1987 - 1996 F150 & Larger F-Series Trucks" Forum. This being the full size Bronco forum, I hesitate to give you wiring information since you could have a different engine and/or fuel tank setup than the Bronco. The F-series and Bronco were very similar in most respects but I'd hate to give you inaccurate information.
Old 09-05-2010, 10:49 PM
Black Ford XLT's Avatar
Black Ford XLT Black Ford XLT is offline
Black Ford XLT is starting off with a positive reputation.
I agree with the ford dealer replacement saves time and u know its not junk TR
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
1978, 2005, 2008, 2009, explorer, f150, f250, ford, fuel, gas, gauge, guage, problem, problems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
