Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2007, 02:40 PM
Edge68474 is starting off with a positive reputation.
351 W and C
I was wondering what is the difference between the Windsor and Cleveland motors? Is one any better than the other and why?, and how can I tell which one I have?
Thanks.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2007, 04:27 PM
Placermike's Avatar
WAFTE CL
Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.
The easiest way to tell is by looking at the radiator hose...The Cleveland connects directly to the block and the Windsor connects in front of the intake.
The motor design is very different between the two...Liking HP, I would have to go with the 351C.
__________________
"I wear my own kind of hat" (Merle Haggard)
EClampus Vitus Major WM Downie 1849
  #3 (permalink)
Old 05-12-2007, 11:17 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Quote:
Thanks.
351W = Windsor: 6 valve cover bolts, separate timing cover, fuel pump mounts to timing cover with two bolts at 3 and 9 o'clock.
351C = Cleveland & 351M/400: 8 valve cover bolts, timing cover is integral to engine, fuel pump mounts to engine with two bolts at 6 and 12 o'clock (the only FoMoCo OHV engine that has a fuel pump so mounted).
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #4 (permalink)
Old 05-13-2007, 08:47 AM
Smile
Thanks for your replies.
  #5 (permalink)
Old 05-13-2007, 09:52 AM
FTE Ken's Avatar
Administrator
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Moved from Washington Chapter to General engine forum. Let's keep tech threads in the truck sections. Thanks.
__________________
-Ken
Look, I'm gonna have to ask you to go ahead, just come back another time. I got a meeting with the Bob's in a couple minutes.
See "IB Tim" for support.
2006 Roush F150 Project: Roushcharger, Troyer Tuning, 9lb pulley, E-Fans, Headers, Brandmotion GPS, BlueConnect Hands-Free Phone & iPod Direct Connect, Black Head/Tail Lights, Retrax Tonneau, more...
04 F250 King Ranch Crewcab 6L PSD project: DP-Tuner Tuning, MBRP Stainless Dual Exhaust.
00 Ranger Supercab XLT 3.0 V6: Bright Box, Mac Intake, Borla exhaust, my tuning.
RIP: 67 & 75 F100
  #6 (permalink)
Old 05-13-2007, 09:53 AM
Broken40's Avatar
Broken40 is starting off with a positive reputation.
I was told that the m in 351m means midland, is this correct information, i always thought it meant modified.
__________________
4wd 73 F-100 390 FE, 7" lift
WARN hubs 4 bbl Eddies Carb
2wd 79 F-100 351W, C-4 tranny. 4 bbl Eddies carb
"What doesn't kill ya only makes you stronger"
  #7 (permalink)
Old 05-13-2007, 11:47 AM
pud pud is offline
pud is starting off with a positive reputation.
the M means means mega monstrous muddin motor.
The M in 351m stands for...........
wait for it..................
M! and theres nothing more to it.
__________________
2004 Focus zts (60 miles a day round trip to work, stuff it)
87 XLT Bronco bagger
  #8 (permalink)
Old 05-13-2007, 12:35 PM
arctic y block's Avatar
arctic y block has a very good reputation on FTE.arctic y block has a very good reputation on FTE.arctic y block has a very good reputation on FTE.
Modified works for me though as it is modified from the 400. But ya can call it Mary if ya like. The Clever is almost as heavy as an FE. So keep your suspension in mind if ya go that way.
Also the Windsor and cleaver share the small block bolt patteren, and the 351M/400 does not share with the small block
__________________
62 UNI Wide Window SWB 390 C6
66 F350 Flat Bed Hi Pro 427 4 speed
7 4X4 Rangers 84 thu 89
55 Fairlaine Town sedan 272 Ford O Matic
Alaska In Summer. Washington in winter.
Show all the luv ya can while ya can. Or one day ya may be alone
Don't just Modify it Fordifiy it
  #9 (permalink)
Old 05-13-2007, 12:43 PM
Mtthwvn73's Avatar
Mtthwvn73 is starting off with a positive reputation.
I've always heard that the Windsor is good truck motor that makes low end torque and the Cleaveland is a high horse car engine that revs alot more.
I've never owned a cleaveland, but I've got a windsor in my bronco, and it has a lot of low end torque, and I'd rather have that than horsepower any day.
  #10 (permalink)
Old 05-13-2007, 01:16 PM
Both will do either depending on how they are built. But in stock form I tend to agree with you
__________________
  #11 (permalink)
Old 05-13-2007, 01:50 PM
Mtthwvn73's Avatar
I've also heard about the Cleveland having problems oiling in the upper RPM's. I don't know if it's true or not though, just from what I've heard.
  #12 (permalink)
Old 05-13-2007, 02:10 PM
Again in stock form as a daily driver with proper maintenance that's not a problem. But one that needs addressed in High Performance racing engines.
__________________
  #13 (permalink)
Old 05-13-2007, 09:04 PM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
In OEM trim the 351C is at least similar to the 351W in most things except the heads. The 351C 2V head has canted valves and much larger ports that flows better than the 351W (Wheezer) head. The 351C 4V head has monstrous ports and valves, so large that low end performance suffers from lack of velocity but at higher RPM's goes great guns making it a great high RPM powerhouse. For a daily driver I would use a 351W, even for performance since there are now great heads available for the Wheezer.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
  #14 (permalink)
Old 05-13-2007, 10:44 PM
DOHCmarauder's Avatar
DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.
An advantage for the C when used for high RPM work is the smaller mains.
The C is also was offered with 4 bolt mains.........
Again, in stock form, it's really not an issue.
  #15 (permalink)
Old 05-13-2007, 11:52 PM
Clever heads can be put on a Windsor. And works quite well
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
