83 Bronco 302 to 351C engine swap.
on
1 Post
Need help on a engine swap for a 83 Bronco 4x4. Current engine in Bronco is a 302 with a 3 speed automatic w/ a married transfer case. The question is, would a 351c bolt on this transmission? I have been told that the tranny is a C-6 with a small block bell. I have been told that it would and some say it won't. Please let me know.
Thanks Fordzzzz77
Thanks Fordzzzz77
The bellhousing pattern is the same and the motor mounts
are the same. I suppose you could use a 351m/400 rear sump
oil pan and pickup tube. I've never done this but I do know
you might have problems with the exhaust. You would think
you could use headers for a 351m/400 4x4 Bronco/pickup but
I tried using these headers on a 351c in a different setup
and the header will bolt to the heads but the collector hits
the bellhousing.
the bellhousing.
on
1 Post
Thanks Franklin............I figured it would work but needed to hear it from some eles. I do have the rear sump pan and a pick up from a 400. I have a set of headers from a 77 f250 4x4, if it works it would be nice. If not I will have to use stock exhaust manifolds or shorty's. I will post to let you know if it works out.
Thanks again for the info.
Fordzzzz77
Fordzzzz77
