Disable Factory Alarm - 1997 Explorer - Ford Truck Enthusiasts Forums
Old 05-10-2007, 02:58 PM
chmc chmc is offline
chmc is starting off with a positive reputation.
The factory alarm in my friend's 1997 Explorer randomly goes off... She has figured out how to not arm it when leaving the car (manually locking it), but when she forgets or others drive the car, it gets armed... and then goes off randomly on its own. How do I disable the alarm without losing function of the remotes and keypad entry?
Thanks!
mike
Old 05-25-2007, 02:59 AM
LV Dan LV Dan is offline
LV Dan is starting off with a positive reputation.
You can't! I've tried. It is all integrated.
You either need to replace the box (it is in the back on the driver's side) or find the fault that is making the box think it is being broken into. Don't rule out the panic button on the key fob as a problem source.
Also, these systems are sensitive to RF sources. Here in Las Vegas, the emergency radio system jams them or makes them go haywire (a repeater was stuck on once). Other devices like wireless routers could potentially cause problems, although not as likely as something that puts out a lot of power. My remote won't work at a neighborhood Blockbuster. Perhaps it is the device that prevents theft there. Those work by sending out RF which talks to an RFID sensor in the case. The point is, there could be many sources.
03 Aviator alarm keeps going off! mack6820 Explorer, Sport Trac, Mountaineer & Aviator 4 03-09-2013 01:15 PM
O/D off Flashing -Can that alarm be disabled tcatt Explorer, Sport Trac, Mountaineer & Aviator 3 03-27-2008 02:41 PM
disable factory alarm Sam42 Explorer, Sport Trac, Mountaineer & Aviator 0 06-17-2007 11:22 AM
Factory Alarm keeps beeping, how do I disable? wolgie Expedition & Navigator 4 02-18-2006 10:09 PM
How to permanently disable alarm system? noyield Explorer, Sport Trac, Mountaineer & Aviator 1 10-07-2003 08:10 AM
Tags
1994, 1997, 96, 97, alarm, disable, expedition, explorer, f250, factory, ford, mountaineer, sensitive, turn, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
