E4OD EPC solenoid question
1994 E150 4.9 e4od, With yellow and white wire (pulse voltage ?) unhooked the van will shift ok,only shifts real hard. Checking voltage on both sides, wire cut, I read a varying voltage 0-12 volts from PCM and battery voltage on the solenoid side, this can't be correct. Harness checks OK, solenoid pack has been replaced, same symptom. If you connect the wire back together the vehicle bucks and jumps when you road test it and when it's idling it misses like it has an ignition problem. unhook the wire it runs great.
Any suggestions?
Any suggestions?
sorry about not enough info
go to www.fordfuelinjection.com
you will find test prcedures and diagrams
this is a good site for trouble shooting
flyboyd8
04-18-2023 06:50 PM
RED DYE
03-28-2017 08:19 PM
Nathan Kiolbassa
04-29-2016 02:49 PM
flyboyd8
05-15-2008 06:17 AM
