Loose Mirrors, need some advise
Is the whole mirror loose, or is it just loose in the direction it folds?
If it's in the direction it folds I can't help.
If the whole mirror is loose, open the door and pull off the black plastic cover on the inside of the door behind the mirror. There are 4 nuts holding the mirror on, I think two are hiding behind the foam sticker, that you can peel off, and 2 others behind the rubber stoppers that pull out. Tighten those up and you should be good.
tdlt1
1999 to 2016 Super Duty
06-22-2012 07:46 PM
