I am looking in buying a 1986 F150, to replace my 81 f100 both are 4x4. The guy said that the motor is a 351 HO. I have looked and looked and have not found anything that says there is a 351 ho in pick-ups. Some in the police cars. My question is if the motor is a 351 HO, is it a cleveland or winsor ? Thanks
Charles
Charles
Ifyou can't get your answer here, you may want to check with sbftech.com There are some really good engine guys over there.
I had an '85 Bronco with a 351 HO engine. It was a 351 Winsor, not sure what made it the HO, but that is what the air cleaner cover said. It is not an easy motor to find.
No it was not a roller, those didn't appear until the mid 90's. It is a standard flat tappet hydraulic cam with more lift and duration than the standard 351W. It is actually a torque building cam that was designed for boat engines IE: marine cam.
