97 F150 4X4 5.4 (Check Engine Flashing) - Ford Truck Enthusiasts Forums
Old 10-03-2002, 01:34 PM
prudog prudog is offline
prudog is starting off with a positive reputation.
Post 97 F150 4X4 5.4 (Check Engine Flashing)
My 1997 F150 5.4 check engine light came and>
While idling or in Park the RPMs will drop below 500, then the RPMs will jump to about 1100 and then back down constantly,my gas mileage is terrible. On my way to work today the check engine light started flashing (continuously), and when I would accelerate it felt like I was on a gravel road until I reached the speed-limit then it seamed fine, excluding the flashing CE light??? Many Thanks in advance for any help or advice.
Old 10-03-2002, 04:12 PM
Flex_This Flex_This is offline
Flex_This is starting off with a positive reputation.
Sounds like might be a coil pack. That vibration you experience is probably the roughness of running on only 7 cylinders.
Bring it into the shop to have the computer tell ya which cylinder it is. If it's cylinder #4, have them check the coolant plumbing near-by and tighten any loos fittings.
Please let me know if this was it. I just fixed mine for the same reason. BTW, cylinder #4 is up and under the damn cowl.
Old 10-04-2002, 02:46 PM
anthonyk anthonyk is offline
anthonyk is starting off with a positive reputation.
I have a 97 F150, 4.2 liter, 2wd....It too has the same symptoms....Almost no acceleration and the check enginge light flashing....When you step on the gas it just sputters and sputters until you let off....I suppose I will have Ford check the coil pack like the guy above mentioned.....
Old 10-08-2002, 09:01 AM
"My 1997 F150 5.4 check engine light came and>
While idling or in Park the RPMs will drop below 500, then the RPMs will jump to about 1100 and then back down constantly,my gas mileage is terrible."
ANSWER: The above problem was fixed by replacing the EGR valve.
The check engine light started flashing (continuously), and when I would accelerate it felt like I was on a gravel road until I reached the speed-limit then it seamed fine, excluding the flashing CE light??? Many Thanks in advance for any help or advice.
ANSWER: The above problem still exist after the EGR valve was replaced. Guess what I took it to AutoZone and found a misfire on cylinder # 4. I'm presently going through the Haynes manual to find out how to change / test it.
Old 10-13-2002, 02:37 PM
TEEJAY TEEJAY is offline
TEEJAY is starting off with a positive reputation.
Had the same problem on my 97 250LD. Autozone gave me the misfire code for cylinder #5 (305). Bought a new coil for about $50 bucks and changed it in about 5 minutes. If it was one of the back four coils, I would have taken it to a pro, but #5 is right in the front so it was an easy fix! Kudos to Autozone!!!:-)
Old 10-14-2002, 12:58 PM
keibie keibie is offline
keibie is starting off with a positive reputation.
Old 11-20-2010, 10:26 PM
bburkett11 bburkett11 is offline
bburkett11 is starting off with a positive reputation.
97f150
i got a 97 f150 its got the 5.4l engine in it the truck reves real high before shifting runs little rough in park at idle drops way down to 500rpms first and second gear are fine but third gear reves really high like 4500 to 5000 rpms before shifting the check engine light is on and starts flashing when i really get on it after it starts flashing it starts to putter but it keeps going like it dont loose power at all got any ideas what it could be could anyone let me know what it could be....my guess is the idle position sensor well let me know if thats what it could be thanks
Old 11-21-2010, 07:27 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Get your codes read! ..and don't resurrect threads that have been dead for years!
BAD miss 5.4L coil over plugs jbush1721 1997 - 2003 F150 7 11-04-2012 01:37 PM
Flashing check engine light. feeties Modular V8 (4.6L, 5.4L) 5 10-17-2009 11:48 PM
Airbag light error code 32, Help... akidagin 1987 - 1996 F150 & Larger F-Series Trucks 6 12-10-2007 02:00 PM
Fast Flashing 'Theft' light bla1879 1997 - 2003 F150 6 06-23-2007 11:32 PM
flashing dash board lights nosugardaddy 1999 to 2016 Super Duty 6 01-04-2007 04:28 PM
Tags
1997, 2003, 42, 97, check, coil, engine, f150, flashing, ford, light, misfire, pack, pickup, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
