Sign in using an external account
Welcome to Ford Truck Enthusiasts Forums
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community,
at no cost , you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please
join our community today !
05-09-2007, 10:11 AM
Trans help
Hi I am looking for a C-6 trans that would fit my 1967 F-100 4x4.Just need it to be rebuildable. I am in Coeurdalene,ID.
Thanks Scott
__________________
1967 F-100 4X4 390 4spd
1968 Torino GT 390 4spd
05-09-2007, 11:26 AM
Check Craigslist in your area. I know there seems to be a couple C6's that pop up on the Boise list every week.
http://spokane.craigslist.org/
05-09-2007, 11:24 PM
What motor?
05-10-2007, 12:05 AM
Sorry about that its a 390
__________________
05-22-2007, 03:42 PM
I've got one that was rebuilt in '03. Only has a couple thousand miles on it since. Boise area. you buy the truck and the tranny comes with
06-03-2007, 04:35 AM
Have you checked Spaldings? Thats pretty close to you.
06-04-2007, 09:27 AM
1993 Ford F-250
I just pulled a good working C6 out of my truck, but it was behind a 460 and I'm pretty sure it wont bolt to a 390.
__________________
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS WG turbo @ 12psi, 3" DP 4" straight exhaust, 5" stacks, Hypermax cowl induction, IP up 3 flats, DPS stage 1 injectors, GPR LED mod, Pyro/Boost guages-
186whp 363wtq @ 10psi
1986 F-250HD XLT Lariat 4X4 6.9/T19, soup bowl mod, straight pipe.
06-04-2007, 11:07 AM
Quote:
You're right, it won't work. It would work for a 351m/400/429/460, however.
06-04-2007, 11:29 PM
a.k.a. he has one for a non fe block
__________________
4wd 73 F-100 390 FE, 7" lift
WARN hubs 4 bbl Eddies Carb
2wd 79 F-100 351W, C-4 tranny. 4 bbl Eddies carb
"What doesn't kill ya only makes you stronger"
06-20-2007, 08:04 PM
also check at Bills Ford Only in Spokane
http://billsfordsonly.com/
__________________
Tyde
Opportunity is missed by most people because it is dressed in overalls and looks like work.
~Thomas Edison
1997 Explorer XLT 302/V8 auto
1993 FSB 302/V8 auto (donor truck)
1992 FSB 302/V8 5 speed (wrecked)
1977 F-150 400/V8 auto
06-20-2007, 08:13 PM
Ford Parts Guru
2013 Ford Escape
1965/67 F100/350 = 352 only V8 offered. Cruise-O-Matic (MX) only automatic transmission offered.
First year for F100/350 360/390 engines = 1968.
First year the C6 was offered in F100/350 = 1968.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
