96 E 350 Gas Pedal Assembly Help - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-09-2007, 10:28 AM
Helper Helper is offline
Helper is starting off with a positive reputation.
I have a problem. I have a 1996 E 350 with the 7.3 engine. I need a throttle position sensor which is part of the gas pedal assembly. The problem is Ford no longer makes this part (f6uz9f836ba) and nobody in the country has one. It is 1996 and diesel specific. No other model years or gas engines will work. Has anybody ran into this or found a way to replace just the sensor?
I have been searching junk yards but diesel vans are not that popular.
Any help would be appreciated.
Old 05-10-2007, 08:07 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
I've had good luck with hard to find parts here:
junkyarddog.com
This is the part # I come up with for a van. It looks like an old # but it may be available, IDK.
Throttle Assembly (Includes Pedal, TPS, & IVS) 94-97
(Ford) F5UZ-9F836-B (Econoline)
I don't know if this will work for a van but it's worth a try. Like stated below it may not be available either. I wish I could help more, sorry.
TPS (Throttle Position Sensor) 94-97
See "Throttle Assembly" (May not be Available Individually)
(Ford) F2TZ-9B989-C (recently available, haven't confirmed it works yet).
If all else fails you may be able to clean/repair your old TPS.
Old 05-10-2007, 10:06 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
here is the list of part numbers
(Ford) F5TZ-9F836-A (f-Series) 94-95
(Ford) F6TZ-9F836-AA (F-Series) 96-97
I found the assembly here. Not sure if they have it but they list it. Worth a try!
http://catalog.powerstrokeshop.com/p...ts&searchAll=1
I just called the dealer that I use and they said the same thing! discontinued for three years now! and nobody has them! thats crazy! so what that means is if you have a E350 and your tps goes out you call a wrecker to haul it to the bone yard!
I wonder if the pickup pedal can be made to work? would you be able to post a pics of your pedal so we can compare. especially the connectors on both the TPS and idle valiation switch. Maybe you could just buy a pickup tps and swap the sensors over.
Old 05-10-2007, 02:26 PM
tjbeggs's Avatar
helper PM the original poster in this thread. he just removed an engine for transplant from a van/bus. maybe he has the pedal assembly you need. I let him know you were looking for one.
Old 05-11-2007, 09:13 AM
The TPS was cleaned a while back and it lasted for a few months but now it finally has to be replaced.
I called the PowerStroke shop and he did confirm that it is no longer available and there is no stock.
I do not know if a pickup truck pedal assembly will work but it is something I am going to have to try it looks like.
I will PM Cuda Jim to see if he does have a used one.
I appreciate your help and if and when I come up with a solution to the problem I will let you know.
Thanks again
Old 05-12-2007, 08:13 AM
Cuda_jim's Avatar
Helper, FarmboyAC is the guy you want, I think. Give him a try. He just pulled a motor from a van.
PM sent.
Old 05-12-2007, 09:40 AM
tjbeggs's Avatar
Farmboyac told me they were keeping all that PSD stuff for a motor swap into a 79 pickup. sorry to have stuck out on that one.
Helper do you have the ability to take pics and post them of the pedal assembly you have? If you can we can compare tot he truck pedal and see if it might work before you drop the cash to buy one.
Old 05-14-2007, 02:03 PM
I am working on getting pictures. I hopefully can get them tomorrow.
It was worth a shot. Someone out there has a solution to this. It is just a matter if finding it.
Thanks for the help
Old 05-14-2007, 03:12 PM
Suber's Avatar
Suber Suber is offline
Suber is starting off with a positive reputation.
I have seen a few of these assemblies floating around on ebay, for as little as a 100.00.
Old 05-14-2007, 04:27 PM
Cuda_jim's Avatar
Quote:
It's gotta be for a van. According to Ford they are different.
Old 05-18-2007, 10:02 AM
Gene W's Avatar
Gene W Gene W is offline
Gene W is starting off with a positive reputation.
Standard Motor Products list this one
STANDARD MOTOR PRODUCTS Part # TH35 {THROTTLE POSITION SENSOR
for your '96 E350.
I found the listing at Rock Auto. http://www.rockauto.com/
Just do the parts dig down for your model and you will find it in the Emissions section.
Click the blue "i" for information and you can veiw three pictures of it to see if it is like yours. It's the sensor only, not the complete pedal assembly.
Gene
Throttle position sensor help Farmboypowerstroke 1999 - 2003 7.3L Power Stroke Diesel 4 09-30-2015 07:41 AM
1991 7.3 IDI to 7.3 PSD swap questions IsaLandr 1994.5 - 1997 7.3L Power Stroke Diesel 9 12-13-2014 01:48 AM
code P0122 Throttle pedal position sensor nickt916 1999 - 2003 7.3L Power Stroke Diesel 15 11-30-2013 06:15 AM
1989 f350 deasel 7.3l shifting prob. bigtone1978 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-01-2013 01:10 AM
Accelerator pedal Skweeker General Diesel Discussion 2 12-20-2005 10:10 AM
Tags
1996, 1997, 350, 97, assembly, change, diesel, e350, ford, fseries, gas, pedal, position, recalls, sensor, throttle, tps, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
