Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-09-2007, 01:32 AM
yobuda's Avatar
yobuda yobuda is offline
Garage is empty, add now
yobuda is starting off with a positive reputation.
Disabling the Key-in Chime
Picked up my new Carbon expy - everything is great so far.
My 1st urge is to get rid of the key-in chime - does anyone have the steps to do this?
  #2 (permalink)
Old 05-09-2007, 04:28 AM
Monsta's Avatar
Monsta Monsta is offline
2005 Ford Excursion
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
It's probably the same as any other Ford.
Pull the tumbler out. There is probably the pin you push in with an awl directly underneath the tumbler. You'll probably have to remove the trim around the steering wheel column. Typically the key has to be in the RUN position (truck not on) for it to pull out.
Remove the key from the tumbler and then reinsert it. The tab that pops up will be the one that you want to cover with tape or any other non-conducting material.
__________________
Ken
"Socialism, like the ancient ideas from which it springs, confuses the distinction between government and society. As a result of this, every time we object to a thing being done by government, the socialist concludes that we object to its being done at all. " -The Law, Frédéric Bastiat, 1850
  #3 (permalink)
Old 05-09-2007, 09:27 AM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
2007 Ford F-250
My Garage
MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.
You can also take the easy hack way out and just cut the key sense wire
__________________
Chris - Avid Winter Hater
2007 F-250 XLT 4x4 CC SB 6.0 PSD - ARP, IPR GEn2 EGR Delete, 4" turbo-back, no muffler, no cat, 6.4 banjo bolts, SCT X3, Tenney 270A alt, coolant filter, air bags, Ranchos, etc.
1994 Mustang GT - HCI, MM suspension parts, etc Novi2k waiting on the shelf
Hope & A Prayer Motorsports
  #4 (permalink)
Old 05-11-2007, 09:13 PM
yobuda's Avatar
Quote:
Got a wire color and location?
_____________________
'07 Expedition - Carbon
2nd row captains, power everything
'02 350 PSD CC SB
4" Turbo back exhaust / Acetoned badges / AIH Delete / AIS Intake w/sleeve / Aux backup lights / Blue CPS / Clear cab lights / CCV into exhaust / DS Boost Relief Valve / DS IC Boots / Exhaust brake - SP Diesel w/TC Lockup / Gauges - Boost, Tranny, EGT / Hutch & Harpoon / Headlight harness upgrade / HX crossover / IC wrap removed / IDM / Onboard Air - VIAR 450C & 2.5gl tank / Sonnax-Tricum / SteveRacer / Turbo Master Wastegate / Zoodad
  #5 (permalink)
Old 05-19-2007, 03:50 PM
yobuda's Avatar
Nobody knows?
Also, if I did cut the key sense wire, do you think it would disable the easy-out setting wehre the seat moves back when exiting the vehicle?
'02 350 PSD CC SB
  #6 (permalink)
Old 05-19-2007, 04:19 PM
MisterCMK's Avatar
2007 Ford F-250
My Garage
I am not sure what wire it is or what else it would affect on that vehicle. I know that with older vehicles it was pretty obvious which wire it was when you get under there and that all it did was control the key in chime.
You might try talking to a dealer to see if they can get you a wiring diagram.
__________________
  #7 (permalink)
Old 05-19-2007, 04:27 PM
reneckford64 reneckford64 is offline
reneckford64 is starting off with a positive reputation.
try pulling the fuse out it hase its own one
  #8 (permalink)
Old 05-19-2007, 04:52 PM
MisterCMK's Avatar
2007 Ford F-250
My Garage
Key sense wouldn't have its own fuse
__________________
  #9 (permalink)
Old 05-20-2007, 02:33 AM
Monsta's Avatar
2005 Ford Excursion
Good lord...don't go cuttin' wires on your brand new truck! Especially if you aren't sure what will happen if you do. Covering the contact is simple and effective.
As far as the seat thing...sorry cannot help.
__________________
Ken
  #10 (permalink)
Old 05-20-2007, 09:21 PM
jackson3000 jackson3000 is offline
jackson3000 is starting off with a positive reputation.
You can stop the seat from moving in " set up mode" in the system monitor .The keychime is a pain to listen to. I wouldn't cut wires either.
  #11 (permalink)
Old 05-28-2007, 10:53 AM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
don't cut, it's easier to tape. Plus tape is much easier to remove than trying to resplice if needed
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP w/ Fac Nav and rear DVD
12 Escape Limited
  #12 (permalink)
Old 05-28-2007, 10:39 PM
yobuda's Avatar
Quote:
I'm still looking for what wire to deal with.
No - I do not want to diable the easy-out function. I was just wondering if disabling the key sense would affect it.
'02 350 PSD CC SB
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
