Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-09-2007, 12:28 AM
bio-d bio-d is offline
Garage is empty, add now
bio-d is starting off with a positive reputation.
Question 87 6.9- Is my lift pump bio-d compatable?
Will the diaphragm in my 87 6.9 hold up to long term bio-d use? I've been thinking of changing to an electric pump. I mostly run svo. Would I have to use two electric pumps or could I use one pump for bio-d and the lift pump for the svo? Would the lift pump be damaged while I was running the bio on electric and the lift pump was still pumping without fuel flow out.
Thanks, Mike
  #2 (permalink)
Old 05-09-2007, 01:16 AM
Jacksfirstdiesel Jacksfirstdiesel is offline
Jacksfirstdiesel is starting off with a positive reputation.
I had an '87 and I ran B80 through it no problem. I picked up a replacement lift pump for about $30 just in case from carquest. Never got around to swapping it out before selling it. good luck
Tags
biodiesel, compatable, ford, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
