Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-08-2007, 01:05 PM
tomtoc is gaining momentum as a positive member of FTE.
tailgate net as replacement
just got my f250. the tailgate latch on the bed is messed and the tailgate is trashed as well. i was just going to get one of those cheapo nets since and aftermarket tailgate still needs something to latch on to.
who's used the nets and any brand recomendations? some have solid outer frames and some don't. pros/cons?
seems like a solid outer would hold up better, but also get in the way if i want to load something. as opposed to just collapsing the top and letting the net fall, i'd have to remove the entire setup since i wouldn't really want to step on the framed net.
i'm not looking to start a mpg argument, just wondering about brands/features of different nets.
__________________
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-08-2007, 09:40 PM
wcurtis's Avatar
wcurtis is starting off with a positive reputation.
If you could get a real tailgate it would be better, The nets blow in the wind & they are really hard on the bed sides (shake them)
__________________
2001 f250 SCAB 5.4 2WD LB
16 ft lowe bass bost
30ft aerolite travel trailer
Big Blue
  #3 (permalink)
Old 05-09-2007, 06:27 AM
yea i thought the same. on top of being expensive, i think my bed sides/mounts are bent and trashed.
__________________
  #4 (permalink)
Old 05-09-2007, 10:11 AM
FarmForward's Avatar
'til the cows come home
FarmForward has a great reputation on FTE.FarmForward has a great reputation on FTE.FarmForward has a great reputation on FTE.FarmForward has a great reputation on FTE.FarmForward has a great reputation on FTE.
A friend of mine bought a truck without a tailgate once (in this case, a Dodge, but I'm guessing that other trucks would act the same way). He put a net on the thing, since he planned on using it mainly as a commuter and was'nt going to haul anything with it regularly. Over time the net would get loosened up on one side or the other, so he'd realign it and tighten it back down again, thinking if he did'nt he'd end up with the net alongside the highway somewhere. Eventually it got to the point that it would'nt tighten anymore, because the bed sides had flexed so far out of line that it was impossible to get the thing tighter. He found a tailgate then, but the damage was done by that point. As soon as he'd lower the tailgate, the bed sides would splay outwards. This happened over about a seven year period, but you get the idea.
My opinion: a tailgate is probably best, and they can be had. Just depends on what you are willing to spend for one as far as dents, colour, etc. If you decide to go with a net, though, I'd say it might be a good idea to put a bar across the top of the bed (in the stake pockets, for example) to tie the open end of the truck box together. That would surely help lessen the bed flexing.
__________________
The American Farmer Feeds The World
FarmForward
  #5 (permalink)
Old 05-09-2007, 11:11 AM
yea i thought about the bar idea. maybe a net with a bar across the top....some rubber pads on the bottom of it so it doesn't rattle a ton
__________________
  #6 (permalink)
Old 05-09-2007, 02:01 PM
BPofMD's Avatar
BPofMD has a very good reputation on FTE.BPofMD has a very good reputation on FTE.BPofMD has a very good reputation on FTE.BPofMD has a very good reputation on FTE.
Another choice is to buy one of those "flow thru" tailgates. The come black, are not all metal and simply replace the original tailgate. I got one to use to pull my 5th wheel as mine has the V or U shape. They do come regular tho. I know JC Whitney has 'em. Got mine from Camping World.
__________________
BPofMD
Bud
Maryland Asst. Chapter Leader
& PlankOwner
2005 F250 PSD 4X4 LB Arizona Beige
Prowler 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Join the Maryland Chapter click HERE
  #7 (permalink)
Old 05-09-2007, 02:02 PM
ReAX's Avatar
Bleep Bloop
ReAX is gaining momentum as a positive member of FTE.
i'd vote for a flow thru steel gate. It might run closer to $400, but it will not damage the bed as badly as the netting.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #8 (permalink)
Old 05-09-2007, 02:07 PM
again, my mounting stuff is all shot and bent so anything that mounts on them is out. anyone got some input on types of nets?
edit: i don't want to spend more than $50 or so. anything solid is $200+
__________________
  #9 (permalink)
Old 05-11-2007, 08:12 AM
CaptGuz's Avatar
CaptGuz is starting off with a positive reputation.
i vote for fixing the latches... then getting a tailgate... take the cheap way out of things early means you'll take the expensive way back in later down the road....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
