cracked head?
cracked head?
Hi,
I have a 4.9L 6 in a 92 F150. I posted a couple weeks back about a possible cracked head or blown head gasket. My only symptom is the engine overheats very quickly. I am not getting white smoke out the tailpipe nor am I losing coolant under pressure out a crack in the engine compartment. I've been told that means exhaust gases are getting in the coolant and there would be bubbling in the coolant in the overflow. I checked and I am not getting any bubbling there. All I found was a thin film of white foam at the radiator cap. I removed the spark plugs one at a time and checked the coolant each time. There was no change. Any idea what is causing this? My thermostat and water pump are fine.
Thanks
Thanks
The water pump having to be replaced is what started the whole mess for me. My sepentine belt broke while I was on the freeway. By the time I noticed the temperature spiking, I had driven 5 or 10 miles. The pump was trashed so I replaced it. It is still overheating very quickly. I took the thermostat out with the same result. A buddy of mine who is a mechanic is sure the head gasket blew or the head has a small crack. I want to try a sealant before I remove the head, but I've been told that they won't work if the crack is near any of the pistons
joejackF250
02-05-2015 09:01 PM
That One Fat Guy
05-03-2012 09:20 AM
Struts 'N' Stuff
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
03-21-2004 03:13 PM
