4.6L Hesitation Under Load when HOT... - Page 2 - Ford Truck Enthusiasts Forums
Old 05-17-2007, 09:49 PM
smits03 smits03 is offline
smits03 is starting off with a positive reputation.
I had this similar problem with my 97 F-150 4.6 L, it ended up being a plug that was going bad. The SES light never came on, finally after it did they were able to diagnose the problem.
Old 05-26-2007, 09:51 AM
jsmallwood_2000 jsmallwood_2000 is offline
jsmallwood_2000 is starting off with a positive reputation.
COPs is your answer. I went through all of the same issues, changed this and that, cleaned this and that, over thought many of my symptoms trying to avoid the cops and plugs. Finally changed them out and it runs great now. You can pick them up on ebay for about $20 a piece versus 90 at Ford.
Old 06-01-2007, 09:33 AM
204017782 204017782 is offline
204017782 is starting off with a positive reputation.
I am sure you can check the COP's via resistance, but being that this problem was intermittent I opted for the trial and error method. I broke down and bought one COP. I installed it on the #1 cylinder then took a test ride. This didn't fix the problem. Replaced the #2 COP with the original #1, again did not fix the problem. Did the same thing for #3. Due to accessibility, I jumped over to #6 and bam, the hesitation went away. I could not believe it only took four tries. I drove into work today without the aggravation of surging, bucking etc. Now that the truck runs 99.9% better but I can feel a slight skipping at idle and it seems that I do not have 100% power on top end. Could be my imagination.
Is it common to replace all of the COP's when one goes bad?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 06-01-2007, 10:14 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Common? Yes, when a mechanic talks you into it because they are making money on each COP
Buy another one, and round-robin it again.
Old 08-01-2007, 05:40 PM
tenn250 tenn250 is offline
tenn250 is starting off with a positive reputation.
Had the same problem....
You've probably heard this diagnosis before, but I don't see it here. I had a miss under a load (showed up as engine warmed) for the last two years. If you search under 'miss under load' my post comes up near yours. I have a 99 F250 with the 5.4 and had a plug blew out at 109,000 miles. I had to have the head heli-coiled, and when I did I had Autolite plugs installed.
Well, I moved to Colorado and a few months after being there it started this miss under a load thing. Check engine light came on, and Auto Zone showed it was a bad EGR valve. Replaced it, no change. In fact, I still get a code from that, but that's another story. Well, two weeks ago I decided I'd had enough of the miss and since it was getting worse was afraid it was about to leave me stranded somewhere. I went to the dealership and bought 8 new Motorcraft plugs. In the process of installing them, I found all of the COP boots in good shape with the exception of the #7 boot. It was cracked at the top.... bad. In fact, the guy who did the work I mentioned earlier had apparently siliconed it instead of replacing it. I guess when I got to the dry-cold climate of CO it was too much, and the silicone separated from the boot, and the arching began....and has persisted 'til now. I changed the plugs, but they weren't the culprit, it was a bad boot. Put on a new one, 15.00 bucks form Advance.....MISS GONE.
Sorry so long, but it's a good chance this is your issue to.
Old 08-02-2007, 09:20 AM
Issue was resolved - bad COP on #6 cyl. Truck runs great, however the Check Engine Light decided to come back on. Auto Zone says its is poor EGR flow.
2003 Ford F150 hesitation during driving quackmatt 1997 - 2003 F150 24 08-24-2014 11:10 PM
4.6L Rough Idle/No load hesitation spiggy769 Modular V8 (4.6L, 5.4L) 6 01-09-2013 12:30 PM
6.4 Techs…….Please Offer possible causes and solutions My08F250FX4 6.4L Power Stroke Diesel 17 06-24-2010 11:47 PM
4.6 Skipping cutterjohn 1997 - 2003 F150 2 01-25-2004 12:15 PM
Bad idle in morning and missing under load gdolson 1997 - 2003 F150 7 10-22-2002 09:25 PM
Tags
46, 46l, ford, hesitate, hesitates, hesitation, hot, http46hesitationunderload, load, v8, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
