Installation of rear flip down monitor help - Ford Truck Enthusiasts Forums
Old 05-06-2007, 02:15 PM
AF Mezkin's Avatar
AF Mezkin AF Mezkin is offline
AF Mezkin is starting off with a positive reputation.
I have a 03 Expy with rear air, I just purchased a 12" flip down monitor, DVD player and FM modulator.
I need help in installation if the flip down to the heahliner, the wire diagrams of the o.e.m radio ( 6 disc indash changer 4 speaker set up) to install the FM modulator.
I guess the biggest help that I need is the install of the monitor; do I need to drop the headliner? And if so how do I go about doing this?
Any info from the DIY and the pros will help greatly!
I'll post pics once the install is complete.
Old 05-09-2007, 08:53 PM
STXFitz STXFitz is offline
STXFitz is starting off with a positive reputation.
you don't have to drop it all the way down just enough so you can see what your doing up there usually if you pull the a pillar, b pillar, sunvisors, etc. that is enough
biggest thing to watch is when your pulling on it make sure the headliner is not getting a crease in it.
Old 05-10-2007, 10:41 AM
idbl_fanatic idbl_fanatic is offline
idbl_fanatic is starting off with a positive reputation.
The way mine was installed, was they took a peice of wood, about 12" x 8" and slid up through the hole that was cut in the headliner, and then attached the monitor to that wood. I know this, because I has to replace the monitor not too long ago, as for running the wires, I used a coat hanger.
Old 05-10-2007, 09:49 PM
AF Mezkin's Avatar
idbl_fanatic
Was the peice of wood secured to roof braces or is it there to spread the weight of the monitor across the header panel? How thick was the wood?
Did you route the wire down the "A" pillar?
Rear Seat Entertainment Bodaddio Excursion - King of SUVs 18 11-24-2012 11:59 AM
Flip down DVD player Wopstar Excursion - King of SUVs 4 06-25-2009 12:06 PM
Help installing flipdown in 03 Expy AF Mezkin 1997-2006 Expedition & Navigator 3 05-06-2007 08:06 PM
Excursion aftermarket alarm question RubenG Excursion - King of SUVs 7 11-09-2005 03:00 PM
overhead video console for 1999 w/rear air - help! sfc2001 1997-2006 Expedition & Navigator 6 07-05-2002 09:13 PM
Tags
03, 2001, 2005, cost, doi, expedition, f250, f350, flip, install, installation, instructions, monitor, monitors, sedona
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
