Remove bed or drop tanks
I need to replace fuel pump on front tank on 95f150 check valve filling rear tank and the float assembly on back tank fuel pump not sure which would be easier remove bed or drop both tanks to remove pumps. Also I plan on selling truck so where is best place to get pumps the chain stores don't carry the float assembly not even NAPA
You'd be way ahead to get a buddy or two and remove the bed, especially since you need to work on both tanks. I've done it and it's not that difficult. Spray the bed bolts ahead of time to give the penetrant time to work. Ford still sells the brass floats, a C3AZ part number. Oh, get a set of fuel line tools too.
i will have to do this soon as well since my front sending unit is bad. i hear they come with the pump. . . . regardless, might as well replace everything you CAN down there while you are there.
i will end up raising the bed. i will have help of my engine crane though . . hehe
i will still need to get two buddies to help me though. really, all you need to do is disconnect it, raise it and drive the truck away. thats what i will do.
good luck
good luck
Originally Posted by quicklook2
do not forget to disconnect the fuel fill tube or tubes.
FYI. There are some deals to be had on eBay for these pumps. I have a complete interchange on them if anyone needs it.
Well i just completed this job 2 weeks ago on my buddies chevy. I have done the drop tank method many times. so for kicks and giggles we thought sence we are both pretty big boys that we will remove the bed. All I can say is that is the only way to play with the fuel tanks. Everything is out of your way, and there seemed to be a lot less cussing. Its a easy 2 man job or if you got a tal shop or garage then just wrap some straps around it and hoist it up. you will be very thankful you removed the bed.
Read through this old post. https://www.ford-trucks.com/forums/5...k-problem.html
Yep, Ford still sells the brass floats. If your sender is bad you'll have to bite the bullet, dig deep into your wallet and go to FORD.
I got my pump module for about $40 off of eBay.
An engine hoist will work ....... and you don't have to feed it!
