Brake and turn signal lights not working
Could be a grounding issue...
Check your backup lights, standard lights and license plate light. If those are working, ground is okay.
Could also be a wiring break on just those wires. Hard to see with the protection they get, but could be. Check the wire loom from the back up to the cab for a break by a rock, etc.
Took truck into the mechanic with the additional problem of shifting in and out of overdrive. Don't know if you have ever heard of this but it turned out the hazard flasher switch was out. Noticed all my problems after having truck washed and they turn the flashers on to notify the cleaners I was having a super clean! Guess at that time it was not working but the button stayed in down position, thus all problems began. So, now everything is working properly. Didn't have the flasher fixed for mechanic said the entire dash would have to come out and I have never used it in ten years. He advised to leave it alone. So, that took care of the ABS light, signal lights, brake lights and also the trans problem to boot. He did tell us too that unhooking the battery for a few minutes will reset everything instead of taking fuses out and back in. So, thanks for helping and hope this helps the next one too.
dwcford
26
07-18-2017 10:38 PM
wjstarck
1961 - 1963 F100 Unibody
03-17-2017 03:00 AM
Ronnie Gilliam
08-25-2014 02:12 PM
jhaas63
01-03-2014 06:20 PM
