1983 Bronco Cruise Control Wiring
I have an '83 Bronco and I am installing an aftermarket cruise control. I want to use the existing wiring harness in the engine compartment but my Hanes manual does not do a good job detailing the wiring specs. HELP! Here are the wires that I have:
Orange/Yellow: A/C 12V Accessory
Grey/Black:
White/Pink:
Purple/Lt Blue:
Yellow/Red:
Brown/Lt Green:
As you can see I eliminated one of the wires but have no clue as to where to go from here. Liek I said, I have the Haynes repair manual and these wires are in the diagrams but they do not illustrate which goes to which. There is a vacuum hose coming from my aftermarket cruise control. Where should I hook this up? The old cruise control had two vacuum lines but when the previous owner put in a 351 he cuts these lines and did not bother to hook them up again. Thanks for any help you can give me!
Brent Smith
Proud '83 Big Bronco Owner (for only two months!)
Grey/Black:
White/Pink:
Purple/Lt Blue:
Yellow/Red:
Brown/Lt Green:
Brent Smith
joelswork
09-13-2010 07:09 PM
