Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-05-2007, 02:37 AM
piper350 piper350 is offline
Garage is empty, add now
piper350 is starting off with a positive reputation.
02 ford problems?
I got a 02 f250 7.3 with 56k miles. 2 weeks ago i started using b99 bio diesel. ran one tank and it ran good. thursday evening filled up again, ran it for about a hour and parked it for the night. friday morning-about low 50's turned on the truck and started fine.let it sit for about 5 minutes, put it in gear and stepped on the pedal and it capped at 1500 rpms. i turned the corner from my house and it wouldnt pass 1500 rpms so i parked it and let it sit for a couple of minutes and it idled anywhere from 1500 to 1000 to 750 and then turned off.Turned on and would idle at about 1250 and then dropped till it turned off.Did it about 4 times then it just would not turn on.It sounds like it doesnt get fuel.It is sitting at the stealership at the moment.Any input on possible problems would be greatly appreciated!
  #2 (permalink)
Old 05-05-2007, 07:53 AM
willbd willbd is offline
willbd is starting off with a positive reputation.
Fuel filter
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #3 (permalink)
Old 05-05-2007, 07:56 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Plugged fuel filter. Biodiesel will clean all the "crud" from your fuel system and shove it into your fuel filter.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 05-05-2007, 10:27 AM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
High idle is telling me the temps were cold enouph to engage the ebpv. Wont go above 1500 rpms is 1 of 3 things on our trucks, fuel pump, fuel filter and ebpv closed until truck is warmed up or malfunctioning. Let us know the outcome because I have run everything bad and good in my truck and can tell you I havent event clogged a filter even with bio or veggie.
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #5 (permalink)
Old 05-06-2007, 12:49 PM
well im happy to report it had nothing to do with biodiesel..of course there is a downside...took it to the stealership and $1500 later it was trouble code po1298 and replaced the injection module..I did check the fuel filter before i had it towed and it was in good shape. Well I hope this helps some for any future reference.
  #6 (permalink)
Old 05-06-2007, 06:09 PM
Thanks for letting us know the problem. Did the check engine light come on with this error code?
__________________
Bryan Will
  #7 (permalink)
Old 05-06-2007, 06:55 PM
no check engine light, no indication of any problems until i put it in gear and stepped on the pedal...seemed like a good morning until the module decided to go down..
Tags
code, error, f350, po1298
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
