Hot Shot's Secret - Oil Additive - Ford Truck Enthusiasts Forums
Old 05-04-2007, 12:38 PM
Reidicus's Avatar
Reidicus Reidicus is offline
Reidicus is starting off with a positive reputation.
Just recieved a bottle of Hot Shot's Secret Oil Additive. Going in to do an oil change (perfect timing too!) and test it out to see if it will improve my injectors. Anyone tried it yet and noticed any improvements?
Old 05-04-2007, 02:11 PM
msgtg's Avatar
msgtg msgtg is offline
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
Never heard of it. IMO, I wouldn't add it until you hear from more of the experts.
Old 05-04-2007, 02:22 PM
a-rod's Avatar
a-rod a-rod is offline
a-rod is gaining momentum as a positive member of FTE.a-rod is gaining momentum as a positive member of FTE.
Ive been wanting to try it as well. Let us know how it works out. suppose to be good stuff.
Old 05-04-2007, 03:14 PM
Reidicus's Avatar
Ok, its in along with the new oil. I'll keep all of you informed.
Old 05-07-2007, 02:19 PM
Georgecls Georgecls is offline
Georgecls is starting off with a positive reputation.
I think you will be very pleased with the results of this additive in your engine. Normally, from a lube engineer's perspective, I am not an additive person and do not recommend them. But in this case, with this engine and its potential problems, this additive really does address the issues of this engine. The additive is totally beneficial and is a win/win in this engine's case. As a preventive measure, it *will* keep your truck out of the shop concerning injector issues...
George Morrison, STLE CLS
Old 05-07-2007, 02:22 PM
a-rod's Avatar
Do you have experience with it Georgecls?
Old 05-07-2007, 03:31 PM
Yes, I do have first hand experience with the product. We had a towing customer (who we sold engine oil to) whose two new Ford wreckers were in the garage with injector issues more than they were out and driving him nuts. We tried the product in total desperation as nothing Ford suggested was working. He was losing considerable dollars in that his brand NEW trucks were essentially non-usable and more than once he had to tow both his new wrecker AND the tow at the same time with one of his old Ford gas engined trucks.
It has been going on two years now and neither truck has seen a Ford garage since using the Hotshot treatment.. I was given the product as samples in the trial stages and have no connection with the seller. Our customer has forgotten that there was ever a problem but continues to use the treatment regularly.
So, yes, I have pesonal experience.... And it works and certainly helps..
Old 05-07-2007, 05:50 PM
WishIhada7.3 WishIhada7.3 is offline
WishIhada7.3 is starting off with a positive reputation.
ford states not to run a oil additive....like stated if a good oil is used in the first place there is no need for it...but to each his own i guess but its only motorcraft CJ4 15w40 for me.
Old 05-07-2007, 06:08 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Ummmm, your name says it all for you, wish.
All I can say, try it...from the sounds of the accolades from George, it can't hurt anything!
Old 05-07-2007, 06:19 PM
TwelveAlpha TwelveAlpha is offline
TwelveAlpha is gaining momentum as a positive member of FTE.
I think not too long ago there was an extensive thread down in the Oil and Lube section where the maker or distributor did get involved in answering a handful of techy type questions. That might be worth a search function to read.
Old 05-07-2007, 07:15 PM
a-rod's Avatar
George thanks for the info, Ive been wanting to try this but have been waiting to here some more storys, Ive heard nothing but good about his product so far, so I think I might order some. I use good oil and have always changed it every 5-7k, now every 5k. But even after the buzz flash I still have a little bit of a stiction issue with some injectors.
Old 05-07-2007, 07:43 PM
I made that name back when i was in the market for a truck but could not find a 7.3 i liked that had under 100k on it so i bought my 04 and love it...although i have had some issue's not due to injectors that i know of...but like i said to everyone his own im just very picky about my oil and keeping it clean...thats why my by-pass was one of the first mods...if others have good luck with it awesome...i just wanted to share the fact that ford states against it...but they also state against fuel additives....good luck to all those running it.
Old 05-07-2007, 11:26 PM
kw5413's Avatar
kw5413 kw5413 is offline
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
George has 2 posts here. Doesn't mean that he doesn't have experience.... Just means he has not had an opportunity to establish credibility here.
Old 05-07-2007, 11:40 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
I for one am against oil additives for several reasons.
1) CI4+ and CJ4 oils are some of the best available for diesels
2) Regular changes of oil and filters is key.
3) Adding additives upsets the oil chemistry and dilutes the additive package in a way that no one really knows.
4) There is no such thing a a miricle cure and while I am sure it may not hurt anything, the addition of it may cause the oil to foam (like Lucas additives) do in a HEUI diesel motor (which the 6.0L is).
5) No way to know how it affects and mixes with your particular brand of oil and if not tested or certifed (not just labeled for use in a diesel)... it may do no harm or it could do a lot of harm?
Bottom line... if your running the proper grade oil and type of oil filter and changing on or before scheduled intervals you'll be fine and money ahead. If anything, it is fuel additives that play a larger part in fuel pump and injector longevity!!!
Old 05-08-2007, 09:17 AM
Believe me, from a lube engineer's perspective, engine oil additives are an absolute, positive no, never. Except in this case. Have you noticed the little lawsuits raging between Ford and Navistar? This engine and its warranty claims are a significant portion of the whole deal. The engine has issues that the finest, cleanest oil will not resolve. The Hotshot additive has helped minimize the uncorrected issue and in my case experience involving two tow trucks, has totally eliminated the injector issues. I am sharing my 'real world' experience with a product I do not sell nor have any relationship with. We tried the additive in a case of total desperation for my friend/customer who had two brand new useless trucks.
So here I was, Mr. No addtives, ever! working with engine oil additives.. BUT, in this case, this engine, if someone is having issues similar to my friend/customer, it is worth a try and there does not seem to be a downside in 2 years of using the product.
Again, I do not sell the product and do not recommend the use of engine or gearbox additives of any type. Except in this case, from my experience.
Hot Shot's Secret ???? Anybody heard of this stuff? Studawg 1999 - 2003 7.3L Power Stroke Diesel 9 08-13-2012 04:27 PM
hot shot secret slowmans 6.0L Power Stroke Diesel 88 05-05-2012 08:21 AM
Best thing for old injectors?? 1982_f150 1994.5 - 1997 7.3L Power Stroke Diesel 10 01-05-2011 11:59 PM
Hot Shot Secret RobertJohn 6.0L Power Stroke Diesel 6 03-12-2010 09:46 PM
Hot Shot Secret RobertJohn 1999 - 2003 7.3L Power Stroke Diesel 6 03-12-2010 01:14 PM
Tags
5w40, additive, buy, company, hot, hotshot, hotshots, msds, nt, oil, primrose, secre, secret, shot, shots
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
