Hot Shot's Secret - Oil Additive
#92
Originally Posted by jimmy-six
I have an "04 with no known injector issues, Are they right around the corner? I wish I knew. For a bottle of the "magic elixer" using 1/2 a bottle every 2nd or 3 oil change I may never know. I don't drive it every day and this is not good. So far this seems like something for me and what I do with my PS.......
#93
#94
Swift,
I am not sure if this is the right thing for you. These guys seem to be a lot smarter about the mechanics of things than I am. The 2 things that come to mind are: 1. You will have moisture in your system from letting is sit. Condensation will build up. 2. When you drive it you are going to build up acids in the oil. Then you are going to let it sit. While it is sitting the acids will build up. They would deplete the motor oil prematurely. So even though you only show 3000 the oil will still be spent. That is why the manufacturers say change oil every 3000 miles or 3 months on a car. I would say change your oil more frequently or add something like the 480M Ultraguard. Just a half quart per oil change. It would help fortify the detergents and dispersants and nuetralize some of the acid you would be building up.
Thanks,
Chris
Thanks,
Chris
#95
#96
#97
#98
#100
#102
#103
Originally Posted by Swift193
I have a farely new truck (2400mi) so I hope I don't need HHS for a while. This is my first diesel and I've heard this before about not driving it every day being bad for the engine. I am retired and do not drive everyday. When I do take the truck out I make sure it gets good and hot. It's not a grocery cart. Most of the time when I take it I go to the airport or Hagerstown which are both about 70+ miles away with some shorter trips in between. What harm can come to the engine by not driving it everyday? I feel very lucky if I get to fly my plane once a week (it is often more time in between flights) and I have never had a problem with those engines. If I plan on leaving the plane sit longer than a month I pickle the top end. What bad things can happen to a diesel and how can they be corrected. Would HHS help this? Thanks, Rex
my $.02 worth (oh, and I'm not an additive kind of guy either -- worked too close to this stuff for close to 30 years at a major oil co...)
#104
My stiction issues happend after I switched over to synthetic. So I have been running 5w40 Duron Synthetic for over a year and a half now and the problem came up when working up north using red diesel. about a month later and I started having cold start problems. (bout -25C most of the time). When I got back, I immediately changed the oil, oil filters, fuel filters, ran some cetane booster and some additives. Still nothing worked to get rid of it. Not even the latest flash. Now HSS is my only hope to save me some $$$.
So maybe synthetic wont help with stiction?? My truck does have high mileage but runs great after warming up.
#105
Interesting. I wonder what the expected MTBF is of our injectors (average life expectancy, as in cycles) is? I wonder if International considers 200k miles about the life they expected them to run for...
If yours are worn out, I doubt the secret sauce will help any, Reidicus. As I understand it, the "design" of the product is for a contaminated or residual state (lubricating oil remnants coked on, burnished on, etc.), but if the mated parts don't match anymore...
Good luck to you, in any case.
On edit, and on another thought: have you considered going back to a non-syn oil?
