How do I install HID head lights on my 1999 Ford Ranger XLT? - Ford Truck Enthusiasts Forums
Old 05-03-2007, 03:06 PM
Shadow_Angel Shadow_Angel is offline
Shadow_Angel is starting off with a positive reputation.
I've searched and searched for any kind of clue on how to do this myself but I can't find a thing about this anywhere on the web. I bought some HID head lights that are supposed to be plus and play but when I lift up the hood of my truck, I have no idea how to even open up the headlight hub. How do I open and remove the stock headlights and install the HIDs? Sorry, I'm vehicularly illiterate.
Old 05-03-2007, 07:12 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
In the back of each light there is a ring with a wire harness running through the middle of it. The ring will turn and slide off of the housing. Pull the ring, harness and bulb straight back, and the bulb will come out. You will most likely have to put the ring on the HID bulbs then reinstall the HID bulbs into the headlight assembly.
After you get the new HID bulbs in the headlight, you just have to mount the ballast and connect the wires. Sence the kit is plug-n-play, the harness that came out of the headlight should plug right into a harness coming out of the ballast. Then you will need run a power and ground for each ballast.
Thinking going HID FordmanNJ 1999 to 2016 Super Duty 30 01-04-2015 02:22 PM
newbie here w/ a Hid question api5471 1999 to 2016 Super Duty 4 11-14-2013 01:48 PM
HID or Halogen? xmontex4 1999 to 2016 Super Duty 48 02-21-2011 08:40 PM
H.I.D's tolliewolly 1999 to 2016 Super Duty 23 10-14-2010 12:41 PM
HID kits in Factory Foglights! santacruzf250 1999 to 2016 Super Duty 3 05-05-2008 12:48 PM
Tags
2001, 2003, assembly, ford, harness, headlamp, hid, hooks, install, lights, ranger, remove, tow, ways, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
