Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-03-2007, 07:14 AM
rmeredit rmeredit is offline
Garage is empty, add now
rmeredit is starting off with a positive reputation.
Oil Life Computer (reset to 100%?)
I changed the oil in my wife's 07 Exp (XLT 4x4) w/ Mobil1 5w20. I started it up & went into the computer to reset the oil life indicator. When I reset it, it only went to 90%. I expected 100%... I tried it a few more times & could only get it to go to 90%. Any ideas why? The book says it should go to 100%.
Thoughts?
-robert
  #2 (permalink)
Old 05-05-2007, 07:37 AM
scarface78 scarface78 is offline
scarface78 is new and has a neutral reputation at this point.
Quote:
Thoughts?
-robert
Maybe there was still some Burned out oil left on the engine walls which got mixed with new oil and sensor senses it?
  #3 (permalink)
Old 05-05-2007, 03:40 PM
screwy's Avatar
screwy screwy is offline
screwy is gaining momentum as a positive member of FTE.screwy is gaining momentum as a positive member of FTE.
Navigate to the oil life display and reset it like you would after an oil change, once reset pushing the button again should de-increment the oil life by 10%, repeatedly pressing this will eventually get you cycled back around to 100%. This will set your default starting oil life, as I understand it 100% = 5000 mile oil changes, yours seems to be set on 4500 mile oil changes, 60% would be 3000 mile changes. There is no oil sensor, at least not one that measures the condition of the oil, instead the oil life is based on a calculation that takes mileage and time into account, it may also incorporate more factors but I can’t be sure. Again, this is as I understand it.
__________________
2013 F-150 Super Crew Lariat, 4x4, 3.5 Eco, 3.55E
Tags
07, 2010, 60, change, f150, life, meter, navigator, oil, reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
