iron head capability
Old 05-03-2007, 01:30 AM
MychalCrowson's Avatar
MychalCrowson
MychalCrowson is offline
im not really familiar with all the different casting numbers, i believe its the D2VE heads that suck bad so besides them, what kind of power are the DOVE and D3 heads capable of on a stroker motor of 545ci or more, stock, ported and otherwise? I've read that a big stroker even with iron heads can potentially make 600hp or better, so which heads would it take to do that and which heads are normally found on the late 70's 460's in pickups and what could you do with them? Are 460 rockers adjustable or would you have to replace with adjustables to run a solid cam, not roller just solid? basically i hope to build a 545 in the future but probably wont be able to afford aluminum heads and roller valvetrain, so a budget stroker if you can call it that
Old 05-03-2007, 08:42 AM
Tiremine's Avatar
Tiremine
Tiremine is offline
Go here and all your questions will be answered.
http://www.reincarnation-automotive.com/
Old 05-03-2007, 02:26 PM
MychalCrowson
that site is a wealth of info youre right just about every question i had is answered in detail thanks for the direction
Old 05-03-2007, 09:24 PM
gulfcrestinc's Avatar
gulfcrestinc
gulfcrestinc is offline
the c-9ve heads are another good choice. any head can be a good power maker with a little finess
Old 05-03-2007, 10:14 PM
darrin1999's Avatar
darrin1999
darrin1999 is offline
except the aforementioned d2ve. that head is hopeless
the d0ve heads are adjustable, as are the c9ve and c8ve- the d3ves are not but can be machined to be. the d3ve heads were used from 1973 to 1987-8 when they went to fuel injection.
Old 05-03-2007, 10:26 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
the problem with the C9VE or any of the early castings is the compression ratio on a stroker. using a 545 for example (4.390x4.5) you have to run a 38CC dish with the piston .010 down in the hole (about the max in the bore and still have good quench) just to get it down to 10:1 compression for use with pump gas. Thats a HUGE dish and will be a full dished piston which will eliminate the quench that you are trying to achieve to keep it from detonating. This is the main reason you will see me say don't use DOVE castings, it's not a cure all. the D3VE casting flow every bit as well, will support just as much HP, are cheaper and more plentiful to buy, and you only need a 18cc dish to achieve 9.95:1 compression, a much easier dish to come up with.
Old 05-04-2007, 05:17 PM
MychalCrowson
I was hoping that the d3's were the ones on pickups because like you said they are more easily come by. i'm am surprised however that you cant get away with 10:1 compression or even more. even with a mechanical cam with 250 or 260 degrees of duration and around .600 lift? 10:1 is pretty good but can you get 600hp with that, i guess with 545 inches its still very possible. the biggest motor ive ever had is my 422 FE so i really have no idea what to expect from a 545 built with even better parts. One more question if nobody minds, how much advantage in power will you gain by using a mechanical cam vs. a hydraulic because i have seen some pretty gnarly hydraulic cams too
Old 05-04-2007, 05:39 PM
darrin1999's Avatar
darrin1999
theres no power advantage to using a solid cam over a hydraulic of equal specs, but with a solid cam you can use more lift and quicker ramp rates, and they arent rpm limited- hydraulic cams will "pump up" and not go much past 6500-7000 rpm regardless of the cam theyre on. hydraulic rollers are even more rpm limited, they cant go past about 6000 without floating. solid rollers and hydraulic rollers do have a power advantage though because they dont have as much friction.
Old 05-04-2007, 09:00 PM
MychalCrowson
so really, since this motor tht i wish to build isnt gonna be a race motor and would rarely if ever see 7000 rpm, a hydraulic cam would work perfectly fine? That would save on cost since i wouldnt have to have the rocker studs machined to accept adjustable rockers
Old 05-04-2007, 10:35 PM
darrin1999's Avatar
darrin1999
yep, a hydraulic cam is fine, you just have to make sure your pushrods are exactly the right length with a push rod length checker. if you want roller rockers though you will have to have the heads machined for studs because any full roller rockers are stud mount. if it doesnt matter then just use the stock stamped steel rockers
Old 05-04-2007, 10:43 PM
monsterbaby
Actually darrin you can use FRPP part number M-6564-C351, they are full roller rockers that are bolt down pedestal style.
Old 05-04-2007, 10:48 PM
darrin1999's Avatar
darrin1999
cool, i actually learned something today
Old 05-05-2007, 02:37 AM
jamies460's Avatar
jamies460
jamies460 is offline
A good Hydraulic camshaft is the Ford Racing M-6250-C460 which has 595/620 Lift, I am using this camshaft with my 557ci rebuild, You can get a bit more lift with a Solid but unless you plan to race it the Hydraulic should do the job...
Old 05-05-2007, 10:12 PM
MychalCrowson
thats a nice cam about what i was looking for, what kind of an idle can be expected in a 545? in a 460 it would be pretty lumpy, does the extra 85 cubes make a difference or would it idle fairly smoothly?
Old 05-06-2007, 09:15 PM
jamies460's Avatar
jamies460
In a 460ci I would say it would have a lumpy idle, but as we are adding nearly 100 extra cubes to the 460ci I would say idle should be fairly smooth....Jamie.
Quick Reply: iron head capability
