I have a 1996 f150 with 351W, 4WD. I put a 2" level kit from daystar on the front. I want to find out what the largest tire size I could use without modifying anything. Would 33's be too much????
Thanks, Shane
The rear wells can hold alot more tire than the front, but if you raised the front 2 inches, 33s outta look real nice under there. Just watch if they are too wide they may hit on the radius arm when you crank the wheel.
