Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-02-2007, 01:15 AM
launchba launchba is offline
Garage is empty, add now
launchba is starting off with a positive reputation.
Question Need 300I6 pushrod guide plates
I am going with screw-in rocker studs and would like to use guide plates also. 1966 300 six. What will work for guide plates?? Thanks in advance.
  #2 (permalink)
Old 05-04-2007, 01:20 PM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
Try Summit Racing or CSK or PAW and do a search for guide plate kits.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
"It'll put out what ever it puts out." fordman75
  #3 (permalink)
Old 05-04-2007, 03:11 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
The way the pushrod holes are machined in the ford heads that slotted kind of a deal with close tolerance on the rod do you really think you need them?
  #4 (permalink)
Old 05-05-2007, 11:30 AM
I think the guide plates are only required if changing a pedestal rocker mount head to a screw in stud head.
__________________
  #5 (permalink)
Old 05-10-2007, 06:48 PM
guide plate, extra info
Some of my rocker studs have grooves worn in the side of them. That tells me the pushrod holes are not lined up with the rockers. So I want to go to screw in studs and guide plates to correct. Bob
  #6 (permalink)
Old 01-09-2011, 02:21 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
I know I'm dredging up an old thread here but does anyone have photos or process shots of this particular modification? I'm converting to roller rockers in a 300 and am just looking for as much information as I can get. Crane part numbers might be helpful as well if anyone knows. Thanks
GS92
__________________
The only stupid question is the one you DON'T ask!
Big Bronco FAQ's
Tags
300, ford, guide, pushrod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
