05-01-2007, 11:44 PM
Heres are the pressures for normal functioning systems
these are all at 90* Ambient Temp.
High Side Pressure :
200 - 310 psi
Low Side Pressure :
(STV, POA, or VIR systems) 28 to 31 psi
(Expansion valve Systems ) 7 to 15 psi
(Orifice Tube Systems ) 24 to 32 psi
The leak fill will work for small leaks but if its a fairly large leak its a waste. Plus I have seen in some instances where it fouls up the a/c compressior.
For oil, you only add oil when oil comes out of it. But if you dont know how much oil was in there to begin with you could add half of the recomended to be safe.
