460 into ranger - Ford Truck Enthusiasts Forums
460 into ranger
Old 04-30-2007, 11:16 PM
bhardy501's Avatar
bhardy501 bhardy501 is offline
bhardy501 is gaining momentum as a positive member of FTE.bhardy501 is gaining momentum as a positive member of FTE.
460 into ranger
Has any one done a 460 into a small ford ranger? I dont know if there is even enough room to do this. I have seen quite a few small block rangers but not a big block.
Old 04-30-2007, 11:39 PM
taisa899's Avatar
taisa899 taisa899 is offline
taisa899 is gaining momentum as a positive member of FTE.taisa899 is gaining momentum as a positive member of FTE.
I've got pics of my buddies 429 ranger. Pm me your email and I'll send them to you
jim
Old 05-01-2007, 10:41 AM
bhardy501's Avatar
Thanks, I have sent you my email address. I have been considering several diff. build ideas like a 460 mustang, but a 460 ranger would be a cool build.
Old 05-01-2007, 12:13 PM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
Might be more of a challenge getting it to hook up. Do some nasty burn outs or dounuts unless you carry a half yard of sand in the bed.
Old 05-01-2007, 12:28 PM
bhardy501's Avatar
4 link or ladder bars and slicks, should make one hook if properly set up. It would be a heck of a ride.
Old 05-03-2007, 02:52 AM
WarWagon WarWagon is offline
WarWagon is starting off with a positive reputation.
Make sure you also runa full cage to tie it all together, let alone protect you when you can't gather it up at 135.
Old 05-03-2007, 08:39 PM
darrin1999 darrin1999 is offline
darrin1999 is starting off with a positive reputation.
just talk to monsterbaby- hes the 460 forum moderator and runs a 460 based stroker in his race truck- a ranger. he should be able to tell you anything you need to know if youre serious about the swap.
Old 05-03-2007, 08:44 PM
bhardy501's Avatar
Thanks, I have just been tossing some ideas around. Nothing serious yet.
Small Block or Big Block? TheDawnof68 1967 - 1972 F-100 & Larger F-Series Trucks 23 09-29-2014 08:07 PM
460 Fuel pump ecentric 68Ranger390 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 06-10-2011 11:52 AM
460 hp and torque numbers?? TS6034 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 09-29-2009 08:32 AM
460 exhaust manifolds unique to 73-79 trucks? BBF250 Engine Swaps 6 03-18-2007 04:20 PM
390 into a 80's or 90's Ranger 4fords Engine Swaps 20 10-07-2004 10:21 PM
Tags
1990, 2wd, 460, big, block, build, fit, ford, frame, kit, putting, ranger, sand, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
