1978 - 1996 Big Bronco
"clunk" when I start
Old 06-11-2001, 07:44 PM
chaser's Avatar
chaser
chaser is offline
This is one of those hard to describe sounds, but I'll give it a go.
When I first accelerate from a standing stop I hear/feel a "clunk" - like the motor is revving up and then the transmission or drive shaft or differential is engaged. I have a '96 EB with the 5.8 engine [:->], limited slip differential and strickly stock except a K&N filter. I run Mobil1 engine oil and recently had the differentials drained and replaced with Mobil1 differential grease. My wife's Nissian Pathfinder SE, 4wd also seems to have this sound.
Appreciate any help/advice given.
Thanks.
Old 06-12-2001, 03:01 PM
gator2000's Avatar
gator2000
gator2000 is offline
This sounds like a problem that I was having also...
I found the answer within the message boards about a year ago, it is your drive shaft. It is a two-piece shaft and the splines within need to be greased.
Old 06-12-2001, 06:04 PM
AlM's Avatar
AlM
AlM is offline
pdrunk
02-11-2015 09:26 PM
bthacker
2004 - 2008 F150
05-13-2010 08:30 AM
rangercape
1983 - 2012 Ranger & B-Series
07-02-2003 02:58 PM
PigFarmer
Oil & Lubrication
11-02-2002 12:11 PM
Critterhunter
10-08-2002 06:42 PM
Quick Reply: "clunk" when I start
