How to remove fuel lines from dual tank switch valve?
Old 07-08-2007, 10:08 AM
kola's Avatar
kola
kola is offline
I'm attempting to remove both the supply and return fuel lines from the switching valve used to switch between the front and rear fuel tanks. This is on a 91 F250 7.3 non-turbo with dual fuel tanks. The fuel lines have a 90-degree boot at the valve with a retention clip. I've pried the clips back, and the boot loosens so I can lift a little. However, the boot/fuel line will not completely come off the switching valve.
I'd appreciate any assistance.
Thanks
Pat
Old 07-08-2007, 11:17 AM
dwkremer's Avatar
dwkremer
dwkremer is offline
I'm not sure of the switch valve, but on the tanks the clip has to be completly removed.
Old 07-08-2007, 01:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
The clips have to be completely removed from the fitting.
There is a ridge around the line that the clip inside opening is smaller than as soon as the clip starts in the fitting.
Old 07-08-2007, 02:05 PM
kola's Avatar
kola
kola is offline
Yup. One flew off into the grass when I pried it off, and I could not find it.
Line came right off and on.
Thanks for the help.
Franken-Truck
Electrical Systems/Wiring
12-18-2011 06:20 PM
BRay09
06-21-2011 12:07 PM
cdevor
09-15-2010 08:11 PM
camperspecial1979
06-21-2009 12:57 PM
ColeinDesoto
12-19-2008 08:35 PM
Quick Reply: How to remove fuel lines from dual tank switch valve?
