Frequent Coil Pack issues
Old 04-30-2007, 07:39 AM
R&RRacing8's Avatar
R&RRacing8
R&RRacing8 is offline
Question Frequent Coil Pack issues
Has anyone else had to replace coil packs as much as I have? 4-5 times on an 02 V8?
Old 04-30-2007, 08:20 AM
phil6608's Avatar
phil6608
phil6608 is offline
Welcome to FTE
it is a common problem, they do go bad and short out with any moisture.
I have an 03 and was having problems with one so I ended up changing them all out.
Old 04-30-2007, 09:21 AM
R&RRacing8's Avatar
R&RRacing8
Is there a better pack I could use to lessen the amount of times I will be spending the money on those suckers?
Old 04-30-2007, 09:44 AM
phil6608's Avatar
phil6608
phil6608 is offline
They do make some aftermarket coils but I don't know if they will last any longer or not but you could try them.
Thees guys sell a few different ones but there not cheap.
http://www.lightningforceperformance...2_173_174.html
Old 04-30-2007, 12:34 PM
PA28150's Avatar
PA28150
PA28150 is offline
My #5 coil went a couple of weeks ago. Thought I was going to get stranded on a deserted country road late at night. I was able to limp home and get it changed out the next day without too much hassle (unless you count the $318.00 as hassle). Now the truck seems to idle and accelerate rougher, with a noticeable increase in vibration.
Anyone else had this kind of experience? I'm wondering which shoe is going to drop next...
Old 04-30-2007, 01:15 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
155,000 on original 2 coil packs, ive even washed under the hood a couple times with no problems..
Old 05-01-2007, 01:34 PM
olbeal's Avatar
olbeal
olbeal is offline
I have an 01 with original cops. You people need to STOP WASHING THE TOP OF YOUR ENGINES. It will cost you in the long run.
Old 05-01-2007, 06:21 PM
fiveights's Avatar
fiveights
fiveights is offline
Got a '99 with 151,000 and original cops...did do the plugs about 2000 miles ago though...
Old 07-08-2007, 10:07 AM
obent's Avatar
obent
obent is offline
I've replaced mine 5-6 times over the last 1 1/2 years or so. same one-driver's side every time. Ford never found the cause....they just keep changing them. Luckily, I think I've only paid twice...the rest were under warranty. One time they told me there was coolant sitting in one of my spark plug holes, and that was probably what caued it. They checked the entire coolant system, and found no leak....I don't get it. 12k since last pack change and all is well....keeping my fingers crossed.
Stevenmed
2004 - 2008 F150
03-11-2016 10:28 AM
YooperBrian
1999 to 2016 Super Duty
16
01-21-2016 01:34 PM
rrichmon
Modular V8 (4.6L, 5.4L)
13
04-24-2013 10:39 AM
trucktech
Modular V10 (6.8l)
13
03-05-2011 07:38 AM
hotrod9399
1997-2006 Expedition & Navigator
07-07-2003 03:23 PM
Quick Reply: Frequent Coil Pack issues
