Frequent Coil Pack issues - Ford Truck Enthusiasts Forums
Old 04-30-2007, 08:39 AM
R&RRacing8 R&RRacing8 is offline
R&RRacing8 is starting off with a positive reputation.
Question Frequent Coil Pack issues
Has anyone else had to replace coil packs as much as I have? 4-5 times on an 02 V8?
Old 04-30-2007, 09:20 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Welcome to FTE
it is a common problem, they do go bad and short out with any moisture.
I have an 03 and was having problems with one so I ended up changing them all out.
Old 04-30-2007, 10:21 AM
Is there a better pack I could use to lessen the amount of times I will be spending the money on those suckers?
Old 04-30-2007, 10:44 AM
phil6608's Avatar
They do make some aftermarket coils but I don't know if they will last any longer or not but you could try them.
Thees guys sell a few different ones but there not cheap.
http://www.lightningforceperformance...2_173_174.html
Old 04-30-2007, 01:34 PM
PA28150 PA28150 is offline
PA28150 is starting off with a positive reputation.
My #5 coil went a couple of weeks ago. Thought I was going to get stranded on a deserted country road late at night. I was able to limp home and get it changed out the next day without too much hassle (unless you count the $318.00 as hassle). Now the truck seems to idle and accelerate rougher, with a noticeable increase in vibration.
Anyone else had this kind of experience? I'm wondering which shoe is going to drop next...
Old 04-30-2007, 02:15 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
155,000 on original 2 coil packs, ive even washed under the hood a couple times with no problems..
Old 05-01-2007, 02:34 PM
olbeal olbeal is offline
olbeal is starting off with a positive reputation.
I have an 01 with original cops. You people need to STOP WASHING THE TOP OF YOUR ENGINES. It will cost you in the long run.
Old 05-01-2007, 07:21 PM
fiveights fiveights is offline
fiveights is starting off with a positive reputation.
Got a '99 with 151,000 and original cops...did do the plugs about 2000 miles ago though...
Old 07-08-2007, 11:07 AM
obent obent is offline
obent is starting off with a positive reputation.
I've replaced mine 5-6 times over the last 1 1/2 years or so. same one-driver's side every time. Ford never found the cause....they just keep changing them. Luckily, I think I've only paid twice...the rest were under warranty. One time they told me there was coolant sitting in one of my spark plug holes, and that was probably what caued it. They checked the entire coolant system, and found no leak....I don't get it. 12k since last pack change and all is well....keeping my fingers crossed.
HELP with coil pack and plugs 2009 250 Tommy B405 1999 to 2016 Super Duty 1 08-05-2015 08:38 AM
Coil packs? 1badton Modular V10 (6.8l) 4 06-25-2011 03:13 PM
1996 ford explorer Ignition coil pack specification vabenni Explorer, Sport Trac, Mountaineer & Aviator 1 06-22-2007 05:35 AM
Coil Packs..... DickyBoy 1999 to 2016 Super Duty 5 05-03-2006 07:10 AM
Coil Pack pilot10 Modular V8 (4.6L, 5.4L) 8 12-10-2003 05:25 PM
Tags
04, 06, 2005, 46, bad, coil, coilpack, coilpak, expedition, f150, ford, lightning, pack, packs, problems, recall
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
