2000 F150 4x4 5.4 Trans or Rear diff problem - Ford Truck Enthusiasts Forums
Old 04-29-2007, 04:12 PM
atlford atlford is offline
atlford is starting off with a positive reputation.
Hello - I have 95k on my truck and have a strange problem. When ever I am taking off from a stop AND turning I get either a strange transmission shutter or slip. From what I can tell, it feels like it is coming from the rear end. This does not happen if I am going straight or turning while under way - only from a crawl or a stop (like at a stop sign). Could this be the rear differential or signs of needing the fluid changd in the rear diff? I do tow a boat in the summer, so it does get a work out about once a week. Thanks!
Old 04-29-2007, 06:39 PM
AnOldDog AnOldDog is offline
AnOldDog is gaining momentum as a positive member of FTE.
A shudder is usually associated with the torque converter in your transmission. If so, a complete fluid flush will usually solve the problem. Check your tranny fluid level and check the color. Does it look or smell burnt? This generally occurs as the transmission fluid overheats.
I could be wrong. I've never had it happen to me from a dead stop, and I haven't had it occur only when making only when turning to the right, but then I haven't experienced everything.
Old 04-29-2007, 07:05 PM
puppypower puppypower is offline
puppypower is starting off with a positive reputation.
If your rear is a L/S it could be your clutch pack. A change of fluid and add some friction modifier in the rear should take care of your problem.
Old 04-29-2007, 08:33 PM
Thanks Chris - I will try your idea first and see if that fixes the problem. I will then do a complete trans flush as AnOldDog suggested.
Paul
Old 04-29-2007, 09:26 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
if you have the original gear lube in the back end, then drain and add 2 quarts of 75 w 140 synthetic gear lube and 7 oz bottle of the friction modifier. you can get it at Auto Zone. If the gear lube is only 20-30,000 miles old, then just add the friction modifier to it. too llittle friction modifier will do exactly what you describe with the limited slip rear axles.
Old 04-29-2007, 10:54 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Yup...it's the rear diff. Change the fluid and add 7-8oz of Ford's friction modifier.
It's a very common problem after the truck's seen a lot of miles without a fluid change...
Rear axle movement and diff problems Dan Drover 1987 - 1996 F150 & Larger F-Series Trucks 2 04-06-2015 09:17 PM
Slip Yoke near diff? Junx69 Excursion - King of SUVs 3 07-01-2013 12:49 PM
Clunk on acceleration 79CEEJAY 1999 to 2016 Super Duty 9 04-13-2011 03:13 PM
Road noise sound in front end grizzly041771 1997 - 2003 F150 19 06-26-2008 09:48 PM
Drive train diagnostic help - please? emptyd Excursion - King of SUVs 4 04-13-2007 12:32 PM
Tags
00, 2000, 4x4, 97, defferential, differential, e250, f150, fluid, ford, quarts, rear, shudder, trans, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
