Brake caliper rattle F350 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-29-2007, 12:06 PM
hjesq hjesq is offline
hjesq is starting off with a positive reputation.
Question Brake caliper rattle F350
I have an F350 SD 4X4 Off Road crew cab V10 with an annoying rattle in front brake calipers. How do I fix the problem?
Old 04-29-2007, 02:33 PM
fordtruckman's Avatar
fordtruckman fordtruckman is offline
fordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to behold
you'll probably have better luck in the super duty or diesel forum...
Old 04-29-2007, 03:52 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Welcome to FTE hjesq
I've moved your question to a more appropriate forum for you.
Old 05-01-2007, 10:28 AM
harald harald is offline
harald is starting off with a positive reputation.
Unless a mount bolt is loose I can't imagine the caliper causing your rattle.
If you're checking out the calipers, make sure to clean and lube the slide pins. If they bind up you'll end up with uneven braking or warped rotors.
You might want to check your front shock mounting. I had a rattle coming from one of the front shock lower mounts. Snugged it up and no more rattle.
Old 05-01-2007, 11:46 AM
Pikachu's Avatar
Pikachu Pikachu is online now
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
What year is the truck? Some of the earlier ones had a known issue with swaybar end links rattling. I believe there was a TSB from Ford on this.
Old 05-02-2007, 11:52 PM
I've read up a bit more on my rattle. I've concluded that it's not my brake calipers.
The noise persists when the brakes are applied lightly. I will check all rubber mounted linkages as suggested. I just bought the truck 2 weeks ago and this rattle is it's only defect.
2004 F350 FX4 off road Crew V10 auto long box 122,000 miles.
1990 F350 DRW 5 spd Diesel
HE
'05-'07 Brake caliper torque specs BjornF16 6.0L Power Stroke Diesel 2 11-18-2016 03:17 PM
Brake caliper rattle at slide pins 6_Myles Excursion - King of SUVs 2 03-25-2016 01:57 PM
Caliper Anti-Rattle Clips?? MattyJessome 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-07-2011 01:43 PM
Anti-rattle spring install in caliper Wyatt66f100 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-29-2007 03:10 PM
Disc Brake Question...... 89F150Custom Brakes, Steering, Suspension, Tires, & Wheels 3 05-14-2005 10:34 AM
Tags
braking, f350, rattle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
