Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-29-2007, 08:39 AM
jerrodlewellen jerrodlewellen is offline
Garage is empty, add now
jerrodlewellen is starting off with a positive reputation.
2.5 shakes like hell and wont run very well
so here is the deal, I got a 1999 ford ranger very cheep becouse it had engine problems. it was hard to start, and it would bearly idol. and it wouldnt respond to the gas ped. so I thought it was eather the Idol air valve or the TPS. so I changed both of them and cleaned the throttle body out too. no i can get it to run a little better and I mean a little. but it still shakes like crazy. I noticed that the crank pulley wobbles a little, so I thought that the balancer is bad but I called everywhere and they dont list a balancer for a 2.5 only a crank pulley.
well thats my story.....any ideas guys and gals?
  #2 (permalink)
Old 04-30-2007, 06:31 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
It sounds like it's not running on all four cylinders, or else the timing is off so far that it barely runs. I'd check each cylinder by pulling plug wires one cylinder at a time to see if it drops off any worse (or just dies). Who knows, maybe you got lucky enough that a couple of plug wires got switched.
But the wobbly crank pulley makes me thing that it is indeed a cam timing problem, possibly something has come loose or cracked down there. The timing belt pulley is a cogged pulley behing the crank pulley. You'll want to line everything up and check all your timing marks, maybe even pull the crank pulley off and spin the engine over while looking at the snout of the crank to make sure it's not bent.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 04-30-2007, 08:49 PM
ohh s@#t
well I pulled the belt off the crank pully to pull it like you said and guess what it was loose very loose I could shake it and rotate in with my had and the bolt didnt move with it. and I have tried to take the bolt off and I cant I even braced the braker bar against the frame and used the starter to loosen the bolt and it just stoped the starter...........no budge. HELP ME!!!!
  #4 (permalink)
Old 04-30-2007, 09:00 PM
TigerDan's Avatar
1968 Ford F-250
That's unusual...a starter can almost always break the bolt loose that way. Do you have access to compressed air and an air impact wrench?
Here's a thread with a few suggestions for the same problem:
http://www.ford-trucks.com/forums/60...ming-belt.html
__________________
  #5 (permalink)
Old 05-03-2007, 01:09 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Swap the fuel pump relay with another one in the under-hood relay box once you get the crank pulley fixed, it can cause hard starting, low idling, and extremely rough running with zero throttle response if the fuel pump relay or the fuel pump itself becomes intermittent or just flat out goes bad.
TigerDan is spot on though, I've never had a starter that had access to a good battery not be able to break the crank bolt loose.
  #6 (permalink)
Old 05-03-2007, 07:16 PM
Good And Bad News
I got the pully off "good news", broke the bolt off in the crank "bad news"!
so looks like I am pulling the motor. talked to a engine shop and they said 1200 bucks to rebuild it so I am thinking of swaping the motor with something else. maybe a V-8 ?? or a V-6?
what do you guys think?
  #7 (permalink)
Old 05-03-2007, 11:54 PM
TigerDan's Avatar
1968 Ford F-250
Easiest (and cheapest) thing would be to find a used 2.5 or 2.3 to swap in, then you wouldn't have any wiring or other conversion hassles to deal with. If you wanted to do a V8 conversion, you could find a V8 Explorer or Mountaineer as a donor vehicle and then it's practically a bolt-in swap for your Ranger...but with any conversion, I think you'll be putting a bit more than the quoted $1200 into it, especially if you have to pay someone else to do the work! I'm doing a 5.0 swap on my '89 Ranger, and I've got quite a bit more than that into it...I don't even want to total it up!
__________________
  #8 (permalink)
Old 05-04-2007, 12:27 PM
Even if you swap a 2.3 you think that it would be higher? I thought that the 2.3 was the same thing. I have a friend that has a couple of 2.3 at his shop that I am sure I could get cheep.
  #9 (permalink)
Old 05-04-2007, 06:06 PM
TigerDan's Avatar
1968 Ford F-250
That's why I said the easiest and cheapest thing to do would be to swap in a used 2.5 or 2.3. Swapping in a 2.3 isn't really a conversion, it should be a direct bolt-in swap. It'll only get expensive when you start to swap in engines that were never offered in the Ranger. I'd jump on one of those 2.3 you mentioned...
__________________
  #10 (permalink)
Old 05-04-2007, 07:30 PM
thanks tigerdan you are a big help. is the computers the same in the 2.5 and the 2.3 also?
  #11 (permalink)
Old 05-04-2007, 08:15 PM
TigerDan's Avatar
1968 Ford F-250
That, I'm not sure of. I think however, that if you use all the 2.5 EFI components on the 2.3 that the computer won't know the difference. It's Mass Air, so it should be able to compensate.
__________________
Tags
25, ford, hell, ranger, running, shakes, stay, truck, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
