37 X 12.5's on a 7.5 wheel?
I am looking at upgrading my 35 X 13's to a 37 X 12.5. Would like to keep the same wheels but they are only 7.5 and the 37's suggest an 8.5-11 wheel.
How set in stone is that recommendation?
My current 35's suggest a 8.5-13 wheel and I've never had a problem in 3 years w/the 7.5 wheels but these tires are bigger......
Another issue...
...that may pose a problem is backspacing. Many factory, and some oddball aftermarket wheels in widths less than 8" actually have more backspacing (up to 5") than typical aftermarket aluminum wheels in 8" widths (which have between 4" and 4 5/8" for the most part). This seemingly insignificant anount of backspacing difference can play havoc with turning radius, as the larger tire contacts the frame, leafsprings and/or steering box bolt, depending on 2 or 4WD. I would be just as wary of this as I would be of crowning the tire.
Tim
Tim
FreeDevin
07-02-2010 09:14 AM
FFemt5287
10-20-2007 02:51 PM
