GM axes hybrid pickups until two-mode system debuts in 2008 - Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Old 04-28-2007, 08:23 PM
Red Star Red Star is offline
Red Star has a good reputation on FTE.Red Star has a good reputation on FTE.
Old 04-30-2007, 04:30 AM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
And a good move in my opinion...
I would be even holding off on the "two-mode" system if results out of Scuderi's developmental twin piston engine are anything to go by too...
Old 04-30-2007, 10:44 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
This was all I found about twin piston engines-
http://www.freepatentauction.com/patent?nb=1234
I'm assuming the one you're talking about is a bit better designed?
Old 04-30-2007, 03:20 PM
SMIGGS's Avatar
SMIGGS SMIGGS is offline
SMIGGS has a great reputation on FTE.SMIGGS has a great reputation on FTE.SMIGGS has a great reputation on FTE.SMIGGS has a great reputation on FTE.
The Hemi's are also going to the "two mode" system in 08. Anyone hear of plans for something like this for the Ford Modular engines?
Old 04-30-2007, 06:25 PM
No - that design is similar to the old Junkers Jumo aero diesels.
This involves having two cylinders connected to a common crank (like a V-twin).
The first piston does the induction and compression stroke. The compressed air then goes to a accumulator.
The main advantage to it is that it is so much cheaper to build than a "conventional hybrid".
You also have the advantages of designing the pistons specifically for thier tasks too (power stroke, or compression).
Being able to use the "miller cycle".
Through engine braking you can store the "energy" in the accumulator in the form of compressed air.
You get a much more efficient engine, as the compressed air can be cooled prior to combustion.
Engines that can easily be supercharged - by making a compression cylinder that has a larger bore than the combustion cylinder.
I can't find any websites on it.... will try and scan a schematic when I go home.
Old 05-02-2007, 12:30 AM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is offline
Frankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to all
Old 05-02-2007, 02:43 AM
tanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
