Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Ontario Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ontario Chapter Join Chapter>, Leader: loudfords
  #1 (permalink)
Old 04-28-2007, 04:29 PM
Beast12's Avatar
Beast12 Beast12 is offline
Garage is empty, add now
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Post *** IMPORTANT Message For Ontario Chapter Members! ***
The Webmaster has run an automated routine in the last week for Chapter Memberships. Some of you had your membership removed. Not to worry, there is a reason behind it.
First, check out the following link and see if you are listed or not. If you are, then you don't need to do anything.
http://www.ford-trucks.com/forums/34...r-members.html
If you are not listed (but used to be) here is the reason: the program that was run checked for your location that is listed in your profile. Since this is the Ontario Chapter it was looking for Ontario. If you did not fill that in then it deleted you from the membership list.
All you need to do is click USER CP at the top left then click Edit Profile. In the fourth box down (on the right) put ON. Then scroll down to the Additional Information section. You might as well put your location in there as well. That's the location that shows up in your posts. Then Save Changes.
Now, that is done click Chapter Memberships on the left hand side. Then on the right scroll wayyyyy down to the bottom to the Ontario Chapter. Click JOIN CHAPTER. Send in your request and I will add you to the list again.
If ANYONE has any questions about what to do then DO NOT hesitate to ask.
-Matt
__________________
2000 Windstar
Check Out The Ontario Chapter
"He who is tired of WEIRD AL is tired of life" -Homer Simpson
  #2 (permalink)
Old 04-29-2007, 10:50 AM
Beast12's Avatar
Just an important step to let people know. After you add ON to your profile you MUST do the following:
Quote:
Just adding ON does not add you to the list.
-Matt
__________________
2000 Windstar
  #3 (permalink)
Beast12's Avatar
pinerider added to Chapter Membership.
  #4 (permalink)
Old 04-29-2007, 09:10 PM
Beast12's Avatar
Blackstock added to Chapter Membership.
  #5 (permalink)
Old 04-30-2007, 11:50 AM
loudfords's Avatar
loudfords loudfords is offline
1979 Ford F-150
loudfords has a good reputation on FTE.loudfords has a good reputation on FTE.
Side note: you can only be a member of one chapter any more, not multiple chapters like before.
__________________
Chad - loudfords - Ontario Chapter Leader
Click HERE to join the Ontario Chapter
1979 F150 351W
2003 Explorer XLT
  #6 (permalink)
Old 04-30-2007, 07:24 PM
Beast12's Avatar
That is correct Chad. Thanks for bringing that up. It is a way to help organize the chapters more. Some people were members of up to 10 chapters. Kinda pointless...
-Matt
__________________
2000 Windstar
  #7 (permalink)
Old 05-02-2007, 06:51 PM
Beast12's Avatar
Hillcrest#9 added to Chapter Membership.
waboose added to Chapter Membership.
  #8 (permalink)
Old 05-10-2007, 08:44 PM
Neilster999 Neilster999 is offline
Neilster999 is starting off with a positive reputation.
Thanks I finally found out how to joint i could not figure it out..........Neil from Barrie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
