Why do bigger tires get worse gas mileage? nt
For me, it's cheaper to check my tire pressure every week.
Once that sweet spot is attained, a wider tire will give worse mileage than a narrow tire, all other things being equal (correct inflation, tire design, etc.)
If there is no longer a readable tag on the axle - lift ONE wheel off the ground & mark both the tire & the driveshaft.
Turn the wheel exactly 1 revolution & count the turns of the driveshaft.
Divide the driveshaft revolutions by 2, & that is your ratio.
For instance -
If 1x wheel revolution gives you 7x driveshaft revolutions - you have a 3.55 (or 3.54) axle ratio.
Or 8.25 revolutions would mean a 4.11 axle, & so on.
For instance -
I meant to say DOUBLE (not halve), the driveshaft count.
So.......
1.75x driveshaft revolutions = 3.54 ratio,
2x revolutions = 4.11 etc
bkvanbek
11-26-2013 06:05 PM
bstanart2005
12-27-2010 08:37 PM
Extacie
13
04-11-2009 12:12 AM
