Dually or no Dually
#32
#33
where are your manners
Originally Posted by elemint
If you do not tow then only a fool would get a dually. Besides they look stupid.
#35
For one it is not foolish to have a dually. Like I had said in one of my post they coner better and handle a load much better then a single wheel set up.
Plus if you are in mud or snow. I rather have a dually. Better grip all away around.
Please explain why it is foolish to have a dually.
#36
dually actually gives you less traction in snowy conditions, distributes the weight better which puts less weight on each tire therefore giving you less traction, counter act that by always running good tires, its tough to spend the money sometimes but tires are something that is very important not to cheap out on
#37
#39
If I'm repeating anything in this post I'm sorry but I didn't have time to read all the responses. Duallies are great for towing and I love the looks of them but I'm on my 3rd and I have also had several SRWs and I will never buy another Dually again. If you don't need to pull the weight then there is no advantage what-so-ever. Dually trucks ride rougher, use more fuel, cost more for tires, are helpless in 2 wheel drive if its slick or wet, don't track well in the mud or snow, hard to see around, hard to park in spots, and a lot of other handi-caps with them but they do look good. I've had a 95 Dodge 3500 DRW V10, a 95 F350 PSD CC 4x2 DRW and I currently have a 2000 F350 CC 4x4 DRW Lariat. I much prefer my SRW trucks that I have had over the years.
#40
luckily I haven't had thos problems with mine.
#41
#44
Well any vehicle can get loose when its slick when the power overcomes the traction available but dually trucks are worse especially when you get the low end grunt of a diesel or a healthy big block but what I'm getting at is that there is no advantage to dually wheels if you don't need it for pulling a big nose heavy trailer. Extra tires to buy, less traction, hard to park, wont hardly fit through a drive through window at a bank, or driving in the weather. Of course having weight in the back improves the traction but not to the extent that its better than a SRW. I had to pull a 24' gooseneck up a steep driveway with my 95 DRW CC F350 PSD and I couldn't make it so I had to come back with my 2001 SRW CC F350 PSD to get up the hill and it was just gravel....the duallys wouldnt bite in hard enuff even with a brand new set of Firestone Destination M/Ts on it and I have cheapo Durango M/Ts on the 2001. Just chewed a bunch of the lugs off my new Firestones. After having had the 3 duallies over the last 10 or 12 years, I don't think I will buy another one unless the price is just too good to pass up. Ive had a lot better luck with my SRW trucks.
