Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2007, 12:50 AM
EstevanKingRanch is starting off with a positive reputation.
whats the ideal MPG on a 300I6
i have a 95 f150 auto..just wondering cause i think my MPG suck...havent really calculated it exactly..but its getting noticebly lower MPG..and what could i do to get it up also...
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-27-2007, 04:11 AM
andym's Avatar
andym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud of
Ideal is about 100.
Realistic is 15-18, depending on gears, transmission, and how you drive it.
Calculate it. If you don't know what mileage you're getting, how do you know it's not very good?
__________________
Andy
1989 F-150 XLT Lariat Shortbed 4x4 300/T-18/3.55
1990 Bronco Eddie Bauer 4x4 351/E4OD/3.55
Quote:
It often takes more courage to change your opinion than to stick to it.
Election 2008 results: World's worst job given to a black man.
  #3 (permalink)
Old 04-27-2007, 10:35 AM
well i just pumped 15 gallons the day before yesterday..and so far ive driven about 120miles and i have half a tank left...im going to drive until i absolutely need to pump gas again and calculate it....the reason im doubting my gas milage is because i drove from houston to galveston and back and i used 3/4 of the front tank...in galveston i pumped it up to full and i used a little less than half...the drive was only 50 miles going and 50 miles back at about 75 all the way
  #4 (permalink)
Old 04-28-2007, 07:02 PM
turnerjc03 is starting off with a positive reputation.
assuming that you were equipped with 16 gallon gas tank like my truck that would mean you used 8 gallons of gas to go 120 miles which would then put you at gettin 15 miles to a gallon which is about average. my ford f150 gets 18 miles per gallon but it is fuel injected with a 5speed tranny
  #5 (permalink)
Old 04-29-2007, 04:08 AM
jefxxo is starting off with a positive reputation.
Just filled up my front tank 16 Gallons, and hit 260 miles. And I just flipped 200,000
  #6 (permalink)
Old 04-29-2007, 06:33 AM
srercrcr is starting off with a positive reputation.
Damn, 200,000 miles on 16 gallons....what a deal!
__________________
Steve Robbins
'83 XLT Super Cab Long Bed 300-6 (20 mpg hwy) 4OD 3.08, one-owner ordered from the Factory in May '83 with a page-full of options, 175000 miles, all stainless exhaust. Take a look.....
http://s45.photobucket.com/albums/f88/srercrcr/Ford%20F150/?action=view&current=FordF15083.jpg
  #7 (permalink)
Old 04-30-2007, 08:21 PM
Pkupman82 is gaining momentum as a positive member of FTE.
Quote:
You must tell us your secret 200k on 16 gallons!
__________________
1977 Ford F250 XLT Ranger 4wd/ 351m/ 4 spd
1984 Ford F150 4wd/ 300 six/ 4spd
1996 Ford F150 XLT 2/4wd/ 300 six/ ZF5
1984 Ford F250 XL 4wd/ 6.9/ C6
  #8 (permalink)
Old 04-30-2007, 08:47 PM
okay if i understand you correctly you got 260 miles on 16 gallons of gas well lets do the math. 260 miles devided by 16 gallons of gas = 16.25 in essence then that means your average miles per gallon was 16.25 miles per gallon. and thats not bad considering your truck just rolled over to 200,000 miles.
  #9 (permalink)
Old 04-30-2007, 09:08 PM
okay today i just did the math..i got 253 miles out of 15.3 gallons...so thats 16.5 mpg....thats pretty good i guess...i wish it would be more...i need to change the fuel filter and also clean out the pair of filters i rigged on there
  #10 (permalink)
Old 05-01-2007, 12:40 AM
Quote:
Correct. I just did a tune up at 200,820 miles, pluggs, cap, rotor. And filled up my front tank 16 gallons. I got 266 miles of of it. before switching to my back tank. And Ill addmit I do 50/50 highway/city driving and usually running 75-80 mph on the highway. I really wonder how it would do if I did 70 on the highway. I have to say my truck runs just as good as the day I bought it at 112,000. Oil changes every 3000 miles.
  #11 (permalink)
Old 05-01-2007, 02:00 AM
5.0Torx is starting off with a positive reputation.
ive gotten 23 mpg running 2700 rpm down the highway at 75 mph...
new fuel filter, bed cover, and as light a foot as possible. i bet if i replaced all the sparky stuff i'd get even more.
  #12 (permalink)
Old 05-01-2007, 02:02 AM
the only thing i need is the fuel filter for right now..the dist.cap.rotor.wires.plugs have about 10k miles on them...
  #13 (permalink)
Old 05-05-2007, 01:04 AM
bchunter's Avatar
bchunter is starting off with a positive reputation.
I am getting 16 with my lift and bigger tires. I think that is pretty good for a box in the air.
  #14 (permalink)
Old 10-01-2007, 10:30 AM
jfarcas's Avatar
jfarcas is starting off with a positive reputation.
Wow. The I6 is a strong, efficient engine. I just drove my bone stock (except for the chebbie rocker arms) '76 Supercab 2wd loaded down with about 700 pounds of band equipment and two passengers, and at a steady 60-65 mph on 70% flat, 30% hilly highway driving. I got 90 miles on 4.4 gallons - 20-21 MPG! Very impressive. The 1bbl carb, 4spd T18 tranny, and 3.00 rear end is a great combo, in my opnion.
  #15 (permalink)
Old 10-01-2007, 11:46 AM
cfrives3 is starting off with a positive reputation.
I am only getting about 13 w/ a 4 spd tranny and 3:55 gears, 31 inch tires. I am still working on it though. That is in an 85 Bronco with a fairly heavy foot!
__________________
Charles F. Rives III
65 F-100 2wd-352 4v various mods, pretty quick
83 F-250-Obnoxious 6.9 Diesel on 36's
85 Bronco-still sittin stock, 300 I-6
86 Bronco-Eddie Bauer 408w stroker
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
