You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I know the easy route on my new project,is to install late model running gear. I don't have any running gear in my 35. So I will be buying something. What I was wondering what you guys thoughts were. With today technology,can a 60-70 year old Ford flathead be built. Be dependable and reliable. I am not interested in building a garage show car queen. And trailer cars are not for me. I want to build it to drive local, but if a 1,000 mile rod run comes up. I want to think I have just as much chance to drive in it as one with a later model engine. Its just most things I have had in the past,have been powered by late model V-8s. But I still like the looks and sound of a flathead. I love to have a slightly modified flathead. Whats your input ? Should I forget my thoughts of a flathead V-8 ? Thanks !
Six years ago when I put my 48 pickup on the road, I made a road trip from nw Montana to eastern Ohio by way of Denver, Wichita and Michigan - approx 3500 miles, then straight back to MT another 2250 miles.
It's been my daily driver since and has made trips to: Lethbridge, AB, Canada; Boise, ID; Spokane WA. So yes, I believe they're reliable and dependable. Keeping up with hwy speeds requires road gears in your rear end and/or transmission. OD is the best, but without it run at least 3.50 gears in the rear.
I run a 51 merc V8 in my 48 F1 pickup, HD 3 spd trans with 9" rear with 3.50:1 gears.
So when you rebuilt your flat head,did you build it back stock. Or did you make changes. I was thinking of using a 50s model flathead also. And being I am not trying for a original,I might go for a od too. Thanks !
I haven't worn out my flathead yet, but it's coming close to rebuild time. The one I'm running was used and stock that I pulled out of a big grain truck. I've put about 80,000 miles on it, but now getting a good bit of blowby
My engine is stock internally, but has some added external improvements. You can check my gallery to see the mods I've made - I recommend the mods snowking suggested and then some - just for drivability and road speed issues.
When I do rebuild I'll upgrade to a 3/4 cam but I'll stick with the merc crank and EAB heads (52/52 Ford and the highest compression stock heads). I also plan to bore to 3 5/16" - .125 over and an OD tranny would be nice.
